Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
  #41
Old 10-01-2022, 12:08 AM
nedd nedd is offline
Default Re: MTRX Studio Mic In's / Dolby Audio Bridge...
Originally Posted by LDS View Post
What is the benefit of having the monitors returning into Pro Tools rather than just returning them to DADman?
My point too, Jeff mention I don't need to change anything in Dadman so I looked at the options within Pro Tools but would be much more convenient if the return from DAPS goes, just like HDX, directly to my speakers and HP's.
It does works nicely and was able to monitor thru speakers, BIN Dolby Renderer and Logic with Apple renderer (and dolby renderer) on AirPods. Also listening from Assembler thru Logic works the same way. But without Pro Tools, only on AirPods or 7.1.4 from logic thru DVS on speakers.
___
Mac Studio Ultra, OS 13.6.5 MTRX Studio, PT Ultimate 2023.12.1, HDX1, Sync HD, BM Decklink Extreme 4K, Genelec's 9.1.4, Dolby Atmos Renderer, Avid Dock, S1, SoundFlow, Streamdeck
  #42
Old 10-05-2022, 02:56 PM
Dizaineris Dizaineris is offline
Originally Posted by creativecontrol View Post
AUX IO in Pro Tools 2022.9 - in combination with DAPS, Bridge and HDX:
https://youtu.be/ZdM3HsHuozQ
Jeff
Hi Jeff,
I'm using this exact setup on my system.
I'm working in Post.
Sync feels a little soft with picture.
Is this the delay compensation that can't be avoided by using the Pro Tools Audio Bridge.
Also, I use the numeric keypad in shuttle mode
Slight lag from scrub to actual playback of audio.
If I go back to old way,
PT playback engine set to Dolby Audio Bridge
DAPS output set to HDX
Playback is tight again. Scrub tight as well.
Would be interesting if Pro Tools Audio Bridge could be accessed directly from MTRX Studio- Monitor Profile.
Instead of having to bring it back in to PT.
Mac Studio Ultra 128RAM, HDX Thunderbolt, PT2022.9, MTRX Studio, DVS
  #43
Old 10-05-2022, 03:25 PM
creativecontrol's Avatar
Just like Dolby Audio Bridge, Pro Tools Audio Bridge is a Virtual Coreaudio Device. The Monitor Profile of MTRX or MTRX Studio can only leverage the populated IO that is available to the crosspoint matrix - and (if you have multiple MTRX devices) the unit assigned to ProMon.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #44
Old 10-05-2022, 03:39 PM
Jeff
I guess I was hoping it could be like Dante Virtual Sound Card.
But makes sense.
Thanks for answering
  #45
Old 10-06-2022, 01:30 PM
In the very limited testing I've done so far, I feel the same way about sync to picture.
Scott Gatteño
  #46
Old 10-10-2022, 06:46 AM
Reckless Erik Reckless Erik is offline
Tested the setup suggested without returning re-renders into ProTools. Routed the output of the Dolby Atmos renderer to Dante instead and found that there is a sizeable delay between the output of the HD Native Thunderbolt/MTRX Studio and Dante. Is this due to the inherent delay in Dante or something else?
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
  #47
Old 10-10-2022, 06:48 AM
I'm impressed you got this to work at all, it didn't work for me. Are you using DVS? That has a fair bit of latency, even at the lowest settings.
https://lukehoward.com/
  #48
Old 10-10-2022, 07:10 AM
Hi Luke,
Yes DVS. Actually worked from the get go!
If you want my setup just drop me a line.
[email protected]
Newcomer Audio Post
  #49
Old 10-10-2022, 01:03 PM
LDS LDS is offline
It is working fine here too. The renderer just required some liberal restarting when messing with I/O settings to kick it back into life.
Loopback tests seem relatively easy now that Pro Tools has Aux I/O. At 1024 sample buffers and 48kHz, I am getting the following:
HDN + RME Madi - 56.3ms
HDN + DVS - 62.6ms
HDN + RME Madi + PTAB return to Pro Tools - 72.4ms
DAB + MADI -> HDN - 80ms
HDN + DVS -> PTAB return to Pro Tools - 87.8ms
DAB + DVS -> HDN - 99.5ms
DAB + PTAB return to Pro Tools - 119.8ms
Adding DVS to a previous DAB in/HDN out renderer setup will add a little bit of latency, but it is very little compared to DAB or PTAB are bring to the party.
File Type: jpg Screen Shot 2022-10-11 at 5.49.26 am.jpg (53.3 KB, 0 views)
  #50
Old 10-10-2022, 01:26 PM
HDN + DVS - 62.6ms
Thanks for posting these results.
Very helpful!
Dolby Renderer sync issue with HDX/MTRX Studio remainanon Pro Tools | MTRX & MTRX Studio 7 05-24-2022 02:32 PM
MTRX Studio HDX and Dolby Atmos Production Suite Goombot Pro Tools | MTRX & MTRX Studio 64 09-30-2021 01:02 AM
What brings Dolby Audio Bridge to HDX users? nedd Post - Surround - Video 29 01-03-2020 03:24 PM
Dolby Audio Bridge and AVB RSLAMBERT Avid S1, S3, Dock and Control App 0 11-03-2019 01:46 PM
Dolby Media Producer Suite v2, Decoder, How to get audio to my SPK w HDX and MTRX rig bsteeve Post - Surround - Video 3 08-16-2019 06:19 AM
