Losing Key Command Ability
Ever since I've been using Pro Tools 6, every once in a while I lose the ability to use key commands. It can be anything from a cmd e to a copy or paste to a fade. I am running a G4 single 800 with an HD3 system on OS 10.3.2. Has anybody else experienced this? I have done all the usual trashing prefs, etc...
Thanks, Kevin Nettleingham |
Re: Losing Key Command Ability
I also get this every now and then & can't seem to account for why. It's happened with a mix system & an HD, so definitely is software related.
Joel PT 6.1 Mac 1.25 HD 192 1622 |
I once lost some keyboard functions, OSX / PT 6.1. Turns out I had activated Universal Access in Sys Prefs. Some system prefs can be changed or activated by pressing certain keys a number of times. There's a box to check (or uncheck) in the Universal Access dialog ..."Allow Unversal Access Shortcuts". Don't. Hope that helps.
the Computer: MBP M2 Max the ProTools: PT Studio | MH UNL-8 | Grace m905 | Artist Control the Rest: Amps | UA OX | V72 | Shelford Channel | |
I believe this is a Waves bug where if you don't hit return or esc after entering a value or moving a fader before leaving a waves tdm or AS plug in, it holds on to the keyboard. Very nasty,
If you find that is your experience also please let them know as they seem to be slow at fixing this. |
I'm familiar with the Waves problem. Actually, I don't think that's a bug, I believe that is the way Waves intends their plug-ins to operate. This is a little different. The key commands just stop working. They are grayed out in the menu bar too. This morning I stumbled upon a workaround. If you have another program open and bring it to the active foreground and then go back to Pro Tools, the key commands start working again. PITA but at least I don't have to quit and restart Pro Tools anymore. Hopefully Digi will fix this bug soon.
I see this happen also on my HD2 rig from time to time. Sometimes, if I just perform a save, <cmd-s>, they become available again.
The waves thing IS a bug : it should let go of the keyboard when the plug window is closed-
and it does not always do so. It should only grab the keys when its window is active. The waves thing also causes the commands to be greyed out. |
For anyone who hasn't noticed, if you click on the frame area around the "Load/save" area of a Waves plug window, it will release control of the keyboard.
I also think Waves intends their plugs to work this way. I wish they would change it, it seems so presumptious. This should be a user choice that defaults to "off". |
This thing happens to me also, but not with only Waves open. It can be anytime during a session, but the strange thing is when I go to drop down "Edit" menu to apply the command manually I see them grayed out. Go back to edit window and viola, key commands are back.
It seems to me a bug-like thing (I did the trash prefs etc. thing recently)
HD3 + Control 24 + 2 192s Mac Pro 12 core 2.93 & PT 8 16 Gig RAM Glyph Firewires Motu MTP AV USB |
Losing ability to type in PT dialog boxes | WildHoney | Pro Tools TDM Systems (Mac) | 9 | 11-20-2012 08:27 AM |
Losing ability to type in Dialog boxes | Syn-g | Pro Tools TDM Systems (Mac) | 56 | 04-07-2009 01:46 PM |
Losing ability to select clips in Edit window | kheftel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-06-2009 12:23 PM |
Trim to fit command? I think I'm losing it! | mondoJML | Tips & Tricks | 1 | 12-05-2002 12:08 AM |
Losing [command][shift]B | trombino | Pro Tools TDM Systems (Mac) | 12 | 07-12-2000 06:30 PM |
