Old 12-03-2003, 08:09 PM
egraham egraham is offline
Default Mbox line level input noise using keyboard
Wondering if anyone else has experienced this. When I hook up a keyboard to the Mbox I notice a subtle amount of steady white noise coming from my keyboard (Roland XP-50). Unfortunately this gets recorded to track. One track with the noise is bearable, but after recording mulitple keyboard tracks the noise stacks on top of itself. To a slightly discerning ear this is unacceptable. I feel that the noise levels when using a mic input are very acceptable and multiple tracks with a mic input doesn't cause this problem. I have tried a different Roland keyboard and found the same problem. I should try another brand of keyboard and see if the problem still persists.
Here is what I have done to try and remedy the problem:
-Made sure the output levels from the keyboard were set at their maximum
-Tried multiple types of cables including Monster 100 & 500
-Tried a couple different brands of DI box (even though I know a DI box shouldn't be necessary)
None of this seems to help. If anyone has any suggestions they would be greatly appreciated. Not sure that this is pertinent to my problem, but I'm running PT LE 6.1.2 on an iMac G4.
002 Rack Line input low level beastie boy39 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-13-2008 11:30 AM
JAMLAB - Input Line level very weak - PT 7.3.1 cs4 JazzyJ Pro Tools M-Powered (Win) 4 01-18-2008 01:45 PM
Noise on Mic/Line input 1 turko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-26-2003 09:09 AM
can i run a line level into a hi z input ??? skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-17-2003 02:37 PM
Digi 001's line level inputs 3-8. Control input? dcarlson247 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-26-2001 02:04 PM
