Old 02-25-2003, 10:12 AM
Aquarius Aquarius is offline
Default Analog bus style compression
Hi !
Sorry to ask what one could think as a stupid question, but as I never used an analog board with those relevant features (buss comp), could somebody enlight me on the topic "Tech Talk' (Digizine) : " Applying Analog Style Mix Bus Compression in Pro Tools " ?
Perdon a poor - an young - ignorant [img]images/icons/rolleyes.gif[/img]
Old 02-25-2003, 10:47 AM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
Default Re: Analog bus style compression
Download Analog channel from McDSP and put it on your master fader. Pull up the presets - I think theres a couple caled 'console'. They mimick the SSL / neve onboard master bus compressors. Or buss the ouputs of all your acoustic drums and put AC on an Aux input / return.
That ain't an explanation - but it will give you the effect of it.
Like trying to explain what it fells like to taste chocolate to someone who's never tried it!
Ainslie
http://www.ainsliegrosser.com/
MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio
Old 02-25-2003, 11:14 AM
AE AE is offline
Actually, the point of that article was that in an analog console you can mix a compressed signal with a non-compressed signal but in Pro Tools it's not so simple because of signal processing latency (you get severe phase interference). The article shows you how to work around the problem.
Old 02-25-2003, 06:03 PM
Extreme Mixing Extreme Mixing is offline
With an analog console you can combine the original signal with all its delicious transients and a really compressed version of it, with virtually no time delay and no comb filtering. It's a great sound. You get all the punch of the original sound, but with the gristle and heft of the compressed version and you can blend them to taste. It really works for some sounds. It's a bit of a hastle in Pro Tools, but it can be done.
Steve
Steve Shepherd
Extreme Mixing
Old 02-26-2003, 12:22 AM
ODC ODC is offline
Hi AE,
But what is the aesthetic purpose of this ?
What do you get that you can't have when inserting a comp in a channel or on the master ?
Is it a common use on analog consoles ?
Old 02-26-2003, 10:42 AM
davip davip is offline
Really not much hassle at all. Just bus your tracks to two aux inputs. Insert your compressor (plugin or hardware insert) on one of them and time adjuster on the other to compensate for the latency of the compressor or hardware insert.
Dual 2.3 GHz PowerPC G5
2.5GB RAM
OS 10.4.6
HD 2 Accel
PT 7.1cs9
192 I/O
Old 02-26-2003, 03:19 PM
PTPerson PTPerson is offline
Just setup 2 busses with the same input, both busses containing the same plug in, bypass one, tadaa.
[img]images/icons/smile.gif[/img]
Old 02-27-2003, 03:19 AM
Doug Ring Doug Ring is offline
Or use Audiosuite to generate a compressed version of the original file. Line the two files up on separate tracks and blend to taste.
Old 02-27-2003, 10:29 AM
THETHRILLFACTOR THETHRILLFACTOR is offline
All of these workarounds when the program should just correct the latency on its own. [img]images/icons/mad.gif[/img]
Oh,when Digi..when? [img]images/icons/rolleyes.gif[/img]
Old 02-28-2003, 12:16 AM
I agree that compensation for latency of inserted plugs would be a big plus, but really adding a time adjuster (or, I guess, a bypassed plug) to a bus hardly seems like a big deal, and I think double bussing in the PT mixer is simpler and more flexible than in most other mixers i've used!
2.5GB RAM
OS 10.4.6
HD 2 Accel
PT 7.1cs9
192 I/O
Is a new style DIGILINK cable included with HDX 16x16 analog upgrade phatbeatstudio Pro Tools HDX & HD Native Systems (Mac) 6 05-08-2014 12:18 AM
Console-Style Mix Bus Compression stevedresser83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-08-2008 08:48 PM
Console-Style Mix Bus Compression stevedresser83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-08-2008 07:55 PM
analog style plugs Hannu Lemola Pro Tools TDM Systems (Mac) 2 03-24-2003 04:44 AM
Ok,let's Mix... ...analog style! rat1016 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-16-2000 12:34 AM
