Trying to get 001 to work again, OSX 10.3.9
Haven't been here for a while, as all has been running fine… until now. The system is an "old" Quicksilver G4 running at 733 mHz., with Pro Tools 6.9 installed. The system became unstable, so I did an archive and install of a new 10.3, then updated it to 10.3.9. No issues.
Then I installed PT 6.7, and updated it to 6.9. It seemed to go okay. When I run the Digi Coreaudio Utility, it "sees" the 001. But when I try to start PT, it complains that no Digi hardware is attached. Fixed permissions, etc., but still no go. Incidentally, there is no Digi Preference Panel, but I'm not sure there was one on the previous install. Any help is appreciated! Thanks, Vg |
Re: Trying to get 001 to work again, OSX 10.3.9
The 001 went no further than Pro Tools 6.4 with cs6 and cs9.
Ahhhh, that would answer that. Maybe I can upgrade the 733 to Tiger, then go a bit higher on Pro Tools.
Thanks for the help! Vg |
Tha last version of PTLE that works with the 001 is 6.4cs9. That last version of CAD that works is 6.9. This is all assuming you don't update QuickTime beyond 6.5.2. That seems to be the major dealbreaker with LE 6.4.
I've read reports of the 001 working in Tiger with Core Audio, but never tried it myself since I traded mine for a Delta 1010 PTMP setup. |
Audio Suite plugins that work in 10, do they work in 11? | David Sandwisch | Windows | 1 | 08-10-2013 08:14 PM |
The plugs that WORK and DON'T WORK on 7.0 | The Mink | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 02-10-2006 10:12 PM |
New Mic won't work | DougSt.Louis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-12-2002 09:06 AM |
How does Direct Connect work?? (Does it work well??) | tommydee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-18-2001 08:13 AM |
