Bizarre MBox2 iMac Power Problem
Hello,
I'm having a strange problem. I have a recent iMac and an MBox 2 Pro. When I switch on some other bits of equipment in my setup, the MBox 2 Pro loses its connection with the Mac. Core audio stops working. And if I have PT open I get constant Buffer Under Run messages. Basically, I can't play anything and have to reset the computer. I have a Furman power conditioner. I have tried using different power sockets. The electrics have been checked in the flat by an electrician. I have tried it so that there is absolutely no connection between the bit of equipment switching on and the MBox 2 Pro. Occasionally it seems to happen randomly. I don't have this problem with any other soundcard/ computer combo in my place. Any ideas? It's driving me mad. Thanks! |
Re: Bizarre MBox2 iMac Power Problem
It's not clear if you're doing so, but it's recommended that you NOT use the Mbox 2 Pro power supply...just let it run on bus power.
Thanks for getting back. I'm not using the power supply and never have done. |
intel imac usb does not power mbox2 on start up PTLE7.4 | 1968bob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-01-2008 12:19 PM |
Help: Mbox2 USB power problem from IMac | vocalaccord | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-30-2007 07:58 AM |
Problem w/ Getting Power to MBox 2 from iMac | russcrane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-19-2007 09:26 AM |
mbox2/powerbook power problem... | binaural42 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-05-2006 04:05 AM |
bizarre problem | studioboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-16-2003 05:40 PM |
