Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 12-30-2006, 11:17 AM
GStyle GStyle is offline
Default will i be able to run pro tools le AND m powered?
im getting a macbook inthe very near future. i already have my project mix with m powered. i wanted to have a portable system and a home system, so i was going to purchase an mbox also. my question is will i be able to install both m powered and le on the macbook so when im home, i can connect to the project mix, and when im out use the mbox?
Old 12-31-2006, 02:11 PM
Terry Dycus Terry Dycus is offline
Default Re: will i be able to run pro tools le AND m powered?
Unfortunately, one or the other on a single partition. You could have a partition for M and another for LE I believe.
Best regards,
Terry Dycus
Old 01-01-2007, 04:21 PM
dj j mady dj j mady is offline
Default imac bus speed and project mix from m-audio
does anyone have an imac with a project mix interface.. just wondering if the bus speed on the new imacs is fast enought?
Mac Pro, PowerBook G4, Motif ES6, Project Mix, PT 7.3.1, Turntables, Reason 3.0
MySpace.com/JohnMady
Old 01-08-2007, 01:20 PM
mike.x mike.x is offline
Hi
My portable rig is a Macbook C2D 2.0 with M-Audio Firewire Solo. I use 002s and 002r's at clients home studios. I am running PTLE 7.3 AND PTMP 7.3 on the same machine. You need to install LE first including all cs updates THEN MP. Both versions must be basically the same version (ie 7.3) They share the DAE folder and all plugins.
Hope this helps
OSX 10.4.6 G5 2.0G PT7.3.1 HD3 96io
OSX 10.4.9 Macbook Core2Duo 2.0G 2G Ram PTMP7.3.1 (M-Audio FW Solo) PTLE7.3 (002/002R)
Downgrading Pro Tools M-Powered 9 to Pro Tools M-Powered 8 Rajin macOS 2 09-19-2011 05:37 PM
mac osx, m powered fast track, pro tools m powered singdance6 Pro Tools M-Powered (Mac) 2 12-22-2010 10:24 AM
Please Advise are Pro Tools M-Powered Essential the same as LE M-Powered? jeremiah0812 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-19-2010 11:10 AM
Opening a pro-tools HD session on a windows Pro-Tools LE M-powered system rhodamorgan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-21-2010 06:31 PM
Reading Pro Tools 6 Files on Pro Tools 7 or 8 M-Powered Systems longmansleep Pro Tools M-Powered (Mac) 0 05-08-2010 04:09 PM
