Old 06-01-2006, 10:16 PM
GStyle GStyle is offline
Default mpowered and le on same machine?
is it possible for me to run pro tools through an mbox, AND use the project mix as the main soundcard and controller??
Old 06-02-2006, 05:11 PM
dogselur dogselur is offline
Default Re: mpowered and le on same machine?
My understanding is that if you are using PT LE you can use the Projectmix as a controller only, not as a soundcard. If you use PT Mpowered you can't use your mbox. Question:
1. why do you want to use your mbox if you have the Projectmix? If it is because of the pre's, well, you can record them on the mbox in PTLE then reopen the session in MPowered to mix on the Projectmix. I assume you have version 7.1 on both programs.
dogselur
Old 06-02-2006, 08:29 PM
i lost my pro tools m-powered ilok key, and i was going to borrow a friends mbox2 for a few days til i get a new ilok key.
Old 06-02-2006, 11:04 PM
Mozepy Mozepy is offline
Here is a somewhat off track but related question: When you have both LE and M-Powered installed can you open both at the same time?
New Machine? New Hardware? Purpose built Machine? PatriotsBiker Windows 4 06-30-2013 12:06 AM
mpowered vs le devildragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-28-2010 08:46 AM
MPowered vs LE tangrams Pro Tools M-Powered (Mac) 4 10-20-2010 06:53 PM
Want to re-install Pro Tools MPowered on another machine CJ Beatz Pro Tools M-Powered (Win) 3 06-27-2010 07:34 PM
Machine Control's supported machine J. S. Bach General Discussion 0 01-17-2000 08:06 AM
