Old 05-08-2016, 07:26 AM
shea shea is offline
Default Pro Tools 12 buffer
Hi everybody using digi 003 rack with protools 12 but cant change buffer fron 256 its the only option I have any ideas
Old 05-08-2016, 09:35 AM
JuanPC JuanPC is offline
Default Re: Buffer size
Originally Posted by shea View Post
Hi everybody using digi 003 rack with protools 12 win 10 but cant change buffer from 256 its the only option I have any ideas
ProTools 12 interacts different with different boards, to the soundcard/interface.
Because it has a kind of artificial intelligence...
For example:
I have Lynx AEs16 PCI 19g driver...
With an Intel x58 board I can change buffer size, on the fly...
With an AMD Sr5690 board, I can't.
Same soundcard, same OS, same PT, same all.
The only way to change buffer size is to quit ProTools, and change buffer size in the DSP Mixer configuration menu of the Lynx AES16, and
ProTools will accept the new setting as the only option.
Problem for you...
003 is discontinued, "ProTools blocks discontinued hardware digi001, digi002,"
and W10 support is 12.5 only...
You don't say if you have 12.2, 12.3.1, 12.4 or 12.5
I have HD12.3.1 & W7sp1, works as good as possible.
Tested 12.4 but was a NoGo.
Haven't installed 12.5, but is the same as 12.4 "no bugs fixed," just refreshed code for the Video Engine and The Web features.
Old 05-08-2016, 12:00 PM
Top Jimmy's Avatar
Default Buffer size
If you are using the 003 as the default Windows audio device, don't. Put Windows back to the onboard audio. Likewise, if any other software is using the 003, close it before running Pro Tools.
James Cadwallader
Old 05-08-2016, 02:03 PM
Thank you every body for the quick reply very helpful Class act GUYS
Seamus
Pro tools 11 hw buffer size help!! eddiej1220 Windows 3 06-14-2014 08:22 AM
Pro Tools 9: can't set a H/W buffer size below 128 etelford macOS 4 03-04-2013 09:18 AM
pro-tools 8 HW buffer nandk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 11-11-2009 02:49 AM
Pro tools HW buffer (((((FIX)))))) soulrebel718 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-07-2005 01:47 AM
Pro Tools buffer problems masters tuxstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-27-2005 11:35 AM
