Old 05-07-2021, 07:57 AM
taylor4814 taylor4814 is offline
Default Send / Return w/ Bypassed Reverb
When I set up a Send to an Aux channel with reverb plug-in Insert, but then bypass the plug-in, there's still signal coming through the Aux channel..., is that expected behavior...? I guess I thought the plug-in bypass would mute any signal
Old 05-07-2021, 08:57 AM
Default Re: Send / Return w/ Bypassed Reverb
Yup totally expected. Bypassed plugins not passing signal doesn't make much sense. I automate plugin bypasses on tracks all the time. Say for example I want to turn on a different effect or EQ only for the chorus on a particular track, etc. If you want to hear the signal without any reverb/effects return, just mute the Aux.
Scott Gatteño
Old 05-07-2021, 10:59 AM
I always treat plugins like an effects pedal (the type guitarist use). When you switch it to bypass, the original signal still passes through unaffected like a cable. Therefore it does not mute the signal. If you want to mute the signal, you need to mute the original source track (but effect tails will still linger if present). if you want to take the effect out of the mix, you need to mute the aux (but the source track will still play through without the effect). If you want to mute it completely (source and effect) you need to mute both the original track and the aux that the effect is on. Sorry for being so long-winded, but I just wanted to illustrate the different scenarios at play.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 05-07-2021, 11:11 AM
JFreak's Avatar
JFreak JFreak is offline
No, wrong thinking. Plugin bypass just puts its "mix percentage" to zero, but whatever your send/aux is feeding without that plugin is still going. If you want to kill that send altogether, you need to mute that send (or that aux).
Janne
Old 05-07-2021, 12:00 PM
Ok, thanks,
Old 05-07-2021, 12:19 PM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
It's all about signal flow and components along that signal flow.
Bypass
A Plugin is a component that is inserted into the signal chain to applies all its processing. When you BYPASS that component, the signal goes around that component, hence the name "bypass" and has noe effect on the signal along the signal chain. Keep in mind that the Plugin still receives the in input signal and processes that signal and, therefore, eating up CPU cycles.
This is necessary for automating the Bypass Control. Making a Plugin "Inactive" will also bypass it, but now it doesn't receive any signal and is not processing anything.
Mute
To mute a signal along the signal chain, you would have a Mute switch/button in the signal chain and by enabling that component, the signal flow is interrupted at that point.
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Best way to set up reverb send and return? obidon Pro Tools TDM Systems (Mac) 2 11-10-2010 04:25 PM
Need help with outboard reverb send/return Ruben_B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-04-2005 10:33 PM
send-return external Reverb latency?? thewolffman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-14-2003 10:18 AM
Reverb One bypassed when opening a session stevegalante Pro Tools TDM Systems (Mac) 5 01-29-2001 12:03 AM
Send and Return Spam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-14-2000 10:30 AM
