Old 01-18-2022, 09:04 AM
Rader Ranch Rader Ranch is offline
Default Had there ever been a solution to the mix window issue...
...where sessions from older systems refuse to save the mix window in a second monitor? No matter how/what is revised and re-saved (I'm currently on Ultimate 2020.12.0 but has happened occasionally through the years) the mix window always opens hidden behind the edit window instead of in the second monitor as positioned when saved.
TIA
Old 01-18-2022, 11:06 AM
Ben Jenssen's Avatar
Default Re: Had there ever been a solution to the mix window issue...
TIA
Is there a question?
No. In my experience PT is rubbish at remembering views, windows, and multiple displays, as it has always been. I stopped hoping for a change ages ago. I've settled with saving sessions/templates with all windows on the same screen, and just partly overlapping, so it's easy to either drag the application icon (after hitting F3, Mission Control) to another display, which moves all the windows, or dragging each window to a display/space to have it show up full-screen there. This is Mac, of course.
Old 01-18-2022, 11:52 AM
I believe you read too fast and blew past the question mark. This is hardly a big deal, just a minor annoyance, so I was just seeing if this is one of those things that had an easy fix that I had missed.
Old 01-18-2022, 11:58 AM
K Roche's Avatar
K Roche K Roche is offline
Hard to tell exactly what is being stated and or asked in the OP
I am on PT Ultimate 2021.12 and my sessions save with the correct positions --mix window on one monitor and edit window on the other
What it does not do, is save either display in full screen mode . They stay in the correct position but drop to max screen mode
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 01-18-2022, 01:44 PM
MIX and EDIT always come up here exactly where they were the last time on my 2 screens(both 1920x1080). The only time things get funky is if there is some change or update to the graphics or graphics driver
Old 01-18-2022, 02:04 PM
reichman's Avatar
reichman reichman is offline
Try using Window Configs. Works here on my dual screen 1920x1200 setup.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 01-19-2022, 08:14 AM
I've got sessions from older systems that do not save the mix window in my second monitor. They always open behind (hidden by) the edit window. This has happened every so often throughout the years. It's not just my current version of Ultimate, or one particular era of older session I"m having/had the issue with (that I've been able to identify anyways). We all think differently, I don't know how to be more clear. I have seen the question asked before here, but certainly years ago.
I'll definitely try window configs, should have thought of that, thanks.
Old 01-19-2022, 08:51 AM
TOM@METRO's Avatar
I run 5 monitors, 3 over the console, an 2 at the MIDI station. Window positions are always recalled correctly here.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-19-2022, 09:31 AM
K Roche's Avatar
I don't use window config. But what the heck
I guess I have not noticed that with my older sessions, I'll have to check again. (BTW I always allowed the older .ptf files to convert to .ptx) don't know if that might be an issue ?
OK just checked So when I open my older sessions from as far back as 2003 they open with the edit and mix windows on different displays (Now they may have initially opened one on top of the other) but as soon as I close and save them they open correctly
. Are you saying you still have the issue , if you open the older session and move one window to the other display then Save it , and then reopen it ?
System :
Enjoy the Journey
.... Kev...
Old 01-20-2022, 12:09 PM
Correct...well, until I just found the solution, which is just resizing the mix window a hair smaller on the 2nd monitor. It was already not quite edge to edge (and I never use the green button to go full screen) but whatever the reason that's all it takes to make it go away (or rather, reopen properly). As I mentioned it's been quite a few years since I had this issue, again with older sessions, and if I figured it out then I'd forgotten it. Sucks to get old I tell ya.
HTML code is On
New memory locations window problem and solution tooold macOS 3 02-03-2016 04:52 AM
Latency Issue. No solution works. sidius macOS 5 08-06-2012 07:10 PM
Window Size.....still no solution gofortheheart Windows 2 08-13-2011 08:53 AM
Looking 4 a solution 2 the iMac/MB2Pro issue Voxer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-24-2010 08:05 PM
Any solution for "previous take comes back" issue? Matthew Steel Pro Tools TDM Systems (Mac) 3 02-06-2007 03:34 PM
