Old 09-28-2015, 07:42 AM
Mark Ziebarth Mark Ziebarth is offline
Default Weird behavior of PT 10
I'm using PT HD 10.3.8 on Mac OS X 10.6.8 for a quiet long timer now and last week it started to act weird sometimes. The main problem are random kernel panics when trying to open bigger sessions. And it's not always the same session that makes problems. I tried several and they all fail sometimes…and sometimes not.
I tried to change the boot volume (I have several as backups) but even the start volumes I didn't use for months have the same problems. Has anybody an idea what to do?
Best
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 09-28-2015, 07:47 AM
Southsidemusic's Avatar
Default Re: Weird behavior of PT 10
Hi
First thing I would do is Trash Preferences an databases and restart everything after that and see if it helps, if not then please post all your aystem details and external gear so we can try and help.
There are new versions of PT10 and the last one we have had best success with on 10.6.8 was 10.3.9
Make sure you backup everything BEFORE you do any updates and tricks, the trashing of prefs and dbases doesn't require backups though.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-29-2015, 12:46 AM
Thanks Christopher,
I trashed everything and the system worked flawlessly yesterday. But today the Mac rebooted automatically after I tried to open my first session. I'll come back with more system details later.
Best
Mark
Old 09-29-2015, 12:52 AM
If you are getting OS X kernel panics what do the panic logs in the system console (Console.app) say about them. Any other errors/warnings stand out as possibly interesting in the system logs? cut and paste some of that text here (not screenshots). A full on kernel panic is much rarer than say a DAE error or application crash, and is often caused by a device driver or faulty computer hardware. have you upgraded OS X or any device drivers recently? Another cause may be a corrupted disk/filesystem. Verify all drives. restore back the session that was doing this from a backup and save it someplace else and see if that copy works OK.
Old 09-29-2015, 01:40 AM
Ok Darryl,
I opened up Console and got the following (have to send it in two parts). Can you read anything interesting in it?
Best
Mark
29.09.15 09:15:39 com.apple.launchd[1] *** launchd[1] has started up. ***
29.09.15 09:16:00 com.apple.audio.coreaudiod[115] Tue Sep 29 09:16:00 Mark-Ziebarths-Mac-Pro-2.local coreaudiod[115] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
29.09.15 09:16:00 com.apple.audio.coreaudiod[115] coreaudiod: _RegisterApplication(), FAILED TO establish the default connection to the WindowServer, _CGSDefaultConnection() is NULL.
29.09.15 09:16:00 com.apple.audio.coreaudiod[115] _RegisterApplication(), FAILED TO establish the default connection to the WindowServer, _CGSDefaultConnection() is NULL.
29.09.15 09:16:01 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:01 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:01 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:01 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:01 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:01 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:01 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:01 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:01 com.apple.launchd.peruser.501[122] (com.spotify.webhelper) Unknown key: SpotifyPath
29.09.15 09:16:01 com.apple.launchd.peruser.501[122] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
29.09.15 09:16:01 loginwindow[55] Error loading /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio: dlopen(/Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio, 262): no suitable image found. Did find:
/Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio: no matching architecture in universal wrapper
29.09.15 09:16:01 com.apple.loginwindow[55] 2015-09-29 09:16:01.643 loginwindow[55:107] Error loading /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio: dlopen(/Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio, 262): no suitable image found. Did find:
29.09.15 09:16:01 com.apple.loginwindow[55] /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio: no matching architecture in universal wrapper
29.09.15 09:16:01 loginwindow[55] Cannot find function pointer NewPlugIn for factory C5A4CE5B-0BB8-11D8-9D75-0003939615B6 in CFBundle/CFPlugIn 0x100538000 </Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin> (bundle, not loaded)
29.09.15 09:16:01 com.apple.loginwindow[55] 2015-09-29 09:16:01.646 loginwindow[55:107] Cannot find function pointer NewPlugIn for factory C5A4CE5B-0BB8-11D8-9D75-0003939615B6 in CFBundle/CFPlugIn 0x100538000 </Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin> (bundle, not loaded)
29.09.15 09:16:02 com.apple.launchd.peruser.501[122] (com.apple.Kerberos.renew.plist[155]) Exited with exit code: 1
29.09.15 09:16:02 UserEventAgent[150] Error loading /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio: dlopen(/Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio, 262): no suitable image found. Did find:
29.09.15 09:16:02 UserEventAgent[150] Cannot find function pointer NewPlugIn for factory C5A4CE5B-0BB8-11D8-9D75-0003939615B6 in CFBundle/CFPlugIn 0x100606bb0 </Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin> (bundle, not loaded)
29.09.15 09:16:02 SystemUIServer[127] Error loading /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio: dlopen(/Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio, 262): no suitable image found. Did find:
29.09.15 09:16:02 SystemUIServer[127] Cannot find function pointer NewPlugIn for factory C5A4CE5B-0BB8-11D8-9D75-0003939615B6 in CFBundle/CFPlugIn 0x10201b2c0 </Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin> (bundle, not loaded)
29.09.15 09:16:03 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:03 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:03 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:03 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:03 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:03 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:03 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:03 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:03 com.apple.launchd[1] (com.apple.xprotectupdater[45]) Exited with exit code: 252
29.09.15 09:16:04 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:04 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:04 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:04 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:04 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:04 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:04 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:04 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:04 Snapper[160] == Snapper is trusted ==
29.09.15 09:16:05 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:05 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:05 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:05 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:05 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:05 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:05 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:05 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:06 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:06 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:06 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:06 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:06 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:06 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:06 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:06 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:07 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:07 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:07 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:07 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:07 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:07 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:07 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:07 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:08 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:08 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:08 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:08 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:08 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:08 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:08 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:08 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:09 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:09 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:09 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:09 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:09 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:09 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:09 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:09 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:10 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:10 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:10 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:10 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:10 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:10 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:10 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:10 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:11 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:11 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:11 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:11 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:11 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:11 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:11 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:11 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:12 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:12 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:12 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:12 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:12 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:12 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:12 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:12 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:12 SecurityFixer[180] No insecure startup items found!
29.09.15 09:16:13 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:13 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:13 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:13 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:13 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:13 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:13 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:13 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:14 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:14 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:14 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:14 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:14 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:14 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:14 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:14 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:15 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:15 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:15 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:15 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:15 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:15 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:15 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:15 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:16 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:16 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:16 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:16 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:16 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:16 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:16 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:16 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:17 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:17 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:17 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:17 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:17 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:17 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:17 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:17 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:18 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:18 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:18 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:18 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:18 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:18 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:18 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:18 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:19 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:19 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:19 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:19 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:19 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:19 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:19 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:19 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:20 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:20 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:20 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:20 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:20 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:20 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:20 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:20 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:21 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:21 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:21 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:21 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:21 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:21 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:21 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:21 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:22 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:22 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:22 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:22 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:22 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:22 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:22 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:22 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:23 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:23 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:23 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:23 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:23 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:23 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:23 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:23 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:24 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:24 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:24 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:24 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:24 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:24 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:24 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:24 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:25 System Preferences[191] Error loading /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio: dlopen(/Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio, 262): no suitable image found. Did find:
29.09.15 09:16:25 System Preferences[191] Cannot find function pointer NewPlugIn for factory C5A4CE5B-0BB8-11D8-9D75-0003939615B6 in CFBundle/CFPlugIn 0x200061c00 </Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin> (bundle, not loaded)
29.09.15 09:16:26 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:26 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:26 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:26 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:26 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:26 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:26 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:26 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:27 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:27 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:27 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:27 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:27 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:27 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:27 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:27 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:28 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:28 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:28 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:28 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:28 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:28 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:28 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:28 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:29 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:29 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:29 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:29 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:29 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:29 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:29 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:29 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:30 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:30 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
Old 09-29-2015, 01:41 AM
29.09.15 09:16:30 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:30 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:30 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:30 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:30 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:30 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:31 com.apple.loginwindow[55] usage: ping [-AaDdfnoQqRrv] [-b boundif] [-c count] [-G sweepmaxsize] [-g sweepminsize]
29.09.15 09:16:31 com.apple.loginwindow[55] [-h sweepincrsize] [-i wait] [-l preload] [-M mask | time] [-m ttl]
29.09.15 09:16:31 com.apple.loginwindow[55] [-p pattern] [-S src_addr] [-s packetsize] [-t timeout]
29.09.15 09:16:31 com.apple.loginwindow[55] [-W waittime] [-z tos] host
29.09.15 09:16:31 com.apple.loginwindow[55] ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait] [-l preload]
29.09.15 09:16:31 com.apple.loginwindow[55] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
29.09.15 09:16:31 com.apple.loginwindow[55] [-s packetsize] [-T ttl] [-t timeout] [-W waittime]
29.09.15 09:16:31 com.apple.loginwindow[55] [-z tos] mcast-group
29.09.15 09:16:32 com.apple.loginwindow[55] route: writing to routing socket: No such process
29.09.15 09:16:33 EuControl[210] CoreText: Invalid 'kern' Subtable In CTFont <name: MetaKorrespondenz-Bold, size: 26.000000, matrix: 0x0>
CTFontDescriptor <attributes: <CFBasicHash 0x2c32b10 [0xa0745ec0]>{type = mutable dict, count = 1,
entries =>
1 : <CFString 0xa01d3d78 [0xa0745ec0]>{contents = "NSFontNameAttribute"} = <CFString 0x1e08390 [0xa0745ec0]>{contents = "MetaKorrespondenz-Bold"}
29.09.15 09:16:33 EuControl[210] EuControl finished launching...
29.09.15 09:16:33 EuControl[210] Starting EuCon...
29.09.15 09:16:38 [0x0-0x12012].com.Euphonix.EuConDiscovery[218] Starting to discover, main tid:36179968
29.09.15 09:16:38 [0x0-0x12012].com.Euphonix.EuConDiscovery[218] Successfully inited discovery ORB
29.09.15 09:16:38 [0x0-0x12012].com.Euphonix.EuConDiscovery[218] Successfully created discovery POA
29.09.15 09:16:38 [0x0-0x12012].com.Euphonix.EuConDiscovery[218] Discovering using corba URL: corbaloc:miop:1.0@1.0-EuConDiscovery-1/224.1.239.2:4242
29.09.15 09:16:38 [0x0-0x12012].com.Euphonix.EuConDiscovery[218] Successfully narrowed discovery interface
29.09.15 09:16:38 [0x0-0x12012].com.Euphonix.EuConDiscovery[218] 1 discovery ORB threads started, nice...
29.09.15 09:16:38 [0x0-0x12012].com.Euphonix.EuConDiscovery[218] Starting to Ping...
29.09.15 09:16:39 [0x0-0x11011].com.Euphonix.MC_Client[215] TAO (215|2689566016) Warning: Resource_Factory options ignored
29.09.15 09:16:39 [0x0-0x11011].com.Euphonix.MC_Client[215] Default Resource Factory is disabled
29.09.15 09:16:39 [0x0-0x11011].com.Euphonix.MC_Client[215] Running MC Client...
29.09.15 09:16:44 [0x0-0x11011].com.Euphonix.MC_Client[215] Ping Task Starting...
29.09.15 09:16:55 [0x0-0x11011].com.Euphonix.MC_Client[215] Binding to MC...
29.09.15 09:16:58 EuControl[210] Newest version: 88549
29.09.15 09:16:58 EuControl[210] Newer version availble? No
29.09.15 09:18:04 MIDIServer[262] MIDIServer [262] starting; arch=x86_64
29.09.15 09:18:04 MIDIServer[262] PlugIn DigidesignMbox2MIDI.plugin -- /Library/Audio/MIDI Drivers/ does not contain a supported architecture.
29.09.15 09:18:04 MIDIServer[262] MIDIServer relaunching because a 32-bit driver was found
29.09.15 09:18:04 MIDIServer[262] MIDIServer [262] starting; arch=i386
29.09.15 09:18:04 MIDIServer[262] Failed to create instance for DigiDioMidiDriver.plugin -- /Library/Audio/MIDI Drivers/
please help with this weird behavior Anibal macOS 8 05-05-2013 11:12 AM
Automation Help - Weird Behavior Daniel Sasso Pro Tools TDM Systems (Mac) 4 03-26-2010 10:32 AM
weird region behavior 372cat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-15-2007 10:01 AM
Weird links behavior Oroz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-03-2006 10:00 PM
Weird Behavior from my Mix+ rig dobby12 Pro Tools TDM Systems (Mac) 2 07-28-2005 07:37 AM
