Old 07-21-2013, 06:34 PM
baoboiboi baoboiboi is offline
Default Audio tracks don't match.
I receive MP3 bounce tracks from my partner and use that to record vocal then send the vocal tracks back to him. However, the problem is the vocal tracks are totally off beat when he import them in to his session. They don't match at all.
I've been searching for an answer but couldn't find anywhere then I start thinking that might be because i didn't set the correct tempo when i record vocal tracks. I just leaved it at default 120BPM. Is that a problem? I thought the samples base audio track does't do anything with tempo.
Best
Old 07-22-2013, 02:37 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Default Re: Audio tracks don't match.
As long as you start the recording at the same time the mp3 is sitting in your PT session it should line up.... If you are adding plugins to the vocals and not using delay compensation they may be behind slightly but should line up if nudged into place.
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer
Old 07-22-2013, 06:17 PM
That's why it so strange to me. The audio from my system are playing faster tempo and i see the clips are squeeze in a little bit when import to other system.
Old 07-22-2013, 06:31 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Could that be a difference between 44.1 and 48?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 07-23-2013, 10:50 AM
Now thats true... if you tried to use a 44.1 at 48K without converting it to 48K it will not be the same time and would change slightly in pitch.
Can't match tracks!! critictalk Tips & Tricks 2 08-23-2013 08:12 AM
Match Tracks with FCP? Frank Kruse Post - Surround - Video 1 02-03-2012 02:22 AM
PT10: Import tracks with overlay+match tracks not working Frank Kruse Post - Surround - Video 3 12-02-2011 09:06 AM
Match Tracks Feature doesn't match tracks...... Ryan Butler Pro Tools 9 0 02-26-2011 11:14 AM
Audio and waveform don't match in comp tracks joerusi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-24-2009 02:12 AM
