I just recently started to use my mbox again and while I never had problems before I started it up and now the click track is totally erratic. I tried uninstalling and reinstalling multiple times.
I am running Windows XP and have 3GB in RAM. I also have totally enough power to run this. Is there something that is interfering with the click track? It seems like it is skipping a ton... itll work for a second or two and then stop and all the clicks will come at once. Please help! |
Are you recording to a separate drive (not a different partition of the same drive)?
Have you had PT working properly at any time on your current system? What have you tried uninstalling...PT or the Mbox drivers or both? Might be a good idea to post a Sandra Report.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
hi
I have a similar problem. seems to be a midi sync problem. I use: windows xp home edition sp3 pro tool le 7.3.1 toshiba satellite A110_179.. digidesign 002. someone would know about how to fix it? |
To both of you with troubles, you will not be likely to get any good help without providing the info needed.
Help us Help You - READ THIS Before Posting! Please post a Sandra report. BTW, PC laptops are a total crapshoot for Pro Tools, unless you have the EXACT same model as someone else that DOES have it working well. If you are new to this stuff, know that Pro Tools is very VERY picky about hardware, and that includes the cpu, RAM, chipset, hard drives and graphics.
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
(translated by google)
hello ... dave thanks for reply This is the information:... In pro tool sessions there is a problem with the midi sync and the click track .. as mbender said: itll work for a second or two and then stop and all the clicks will come at once. the same goes for the Instrument track I use the lite version of bfd .. in some cases the midi is in sync and sometimes not .. I follow these steps: trash preference and database files .. The version of pro tool 7.3.1cs7 and my hardware digidesign 002 rack this is the sandra report: SiSoftware Sandra ID Host Name : your-03 Workgroup : WORKGROUP Computer Model : Toshiba Satellite A110 Serial Number : 9620***** Chassis : Toshiba Notebook Mainboard : Toshiba HTW20 Serial Number : 012345****** BIOS : Toshiba V1.30 07/20/2006 Total Memory : 1016MB DDR2 SO-DIMM Processors Processor : Genuine Intel(R) CPU T2250 @ 1.73GHz (2C 1.73GHz, 2MB L2) Socket/Slot : FC µPGA479M (Socket M) Chipset Memory Controller : Toshiba 955XM/945GM/PM/GMS/940GML Express Processor to DRAM Controller 4x 133MHz (532MHz), 2x 512MB DDR2 SO-DIMM 532MHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : Samsung M4 70T6554CZ3-CD5 512MB DDR2 SO-DIMM PC2-4300U DDR2-534 (4-4-4-11 3-15-4-2) Memory Module : Samsung M4 70T6554CZ3-CD5 512MB DDR2 SO-DIMM PC2-4300U DDR2-534 (4-4-4-11 3-15-4-2) Video System Monitor/Panel : LPL Monitor Plug and Play (1600x1200, LP154W01-TLAE, 15.4") Monitor/Panel : LPL Monitor Plug and Play (1600x1200, LP154W01-TLAE, 15.4") Monitor/Panel : LPL Monitor Plug and Play (1600x1200, LP154W01-TLAE, 15.4") Video Adapter : Mobile Intel(R) 945GM Express Chipset Family (8 SP 250MHz, 128MB DDR2 128-bit, Integrated Graphics) Graphics Processor Storage Devices Hitachi HTS541080G9SA00 (80GB, SATA150, 2.5", 5400rpm, 7MB Cache) : 75GB (C:) (E:) MAT[bleep][bleep][bleep][bleep]ADVD-RAM UJ-841S (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Hard Disk (C:) : 29GB (NTFS) @ Hitachi HTS541080G9SA00 (80GB, SATA150, 2.5", 5400rpm, 7MB Cache) Hard Disk (E:) : 45GB (NTFS) @ Hitachi HTS541080G9SA00 (80GB, SATA150, 2.5", 5400rpm, 7MB Cache) Optical Drive (D:) : N/A @ MAT[bleep][bleep][bleep][bleep]ADVD-RAM UJ-841S (ATA33, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Toshiba 82801GBM (ICH7-M) LPC Interface Controller Audio Device : Toshiba 82801G (ICH7) High Definition Audio Audio Codec : Realtek Semi 861 High Definition Audio Audio Codec : Lucent/Agere Systems (Was: AT&T MicroElectronics) HDA softmodem Serial Port(s) : 1 Disk Controller : Toshiba 82801GBM/GHM (ICH7-M) Serial ATA Storage Controller Disk Controller : Toshiba PCI Memory Stick Card Reader Controller Disk Controller : Toshiba PCI SD/MMC Card Reader Controller Disk Controller : Toshiba PCI SmartMedia / xD Card Reader Controller Disk Controller : Toshiba ENE PCI Secure Digital / MMC Card Reader Controller USB Controller 1 : Toshiba 82801G (ICH7) USB Universal Host Controller USB Controller 2 : Toshiba 82801G (ICH7) USB Universal Host Controller USB Controller 3 : Toshiba 82801G (ICH7) USB Universal Host Controller USB Controller 4 : Toshiba 82801G (ICH7) USB Universal Host Controller USB Controller 5 : Toshiba 82801G (ICH7) USB 2.0 Enhanced Host Controller FireWire/1394 Controller 1 : Toshiba VIA VT6308 1394 OHCI Controller FireWire/1394 Controller 2 : TI TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller CardBus/PCMCIA Controller 1 : 64768 CB-712/714 CardBus Controller SMBus/i2c Controller 1 : Intel ICH SMBus Network Services Network Adapter : Realtek RTL8139/810x Family Fast Ethernet NIC - Minipuerto del administrador de paquetes (Ethernet) Power Management Battery No 1 : TOSHIBA PA3465U 44.40Wh/4.00Ah Operating System Windows System : Microsoft Windows XP Home 5.01.2600 (Service Pack 3) Platform Compliance : x86 regards I hope any idea how to fix it |
![]() Quote:
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave Last edited by albee1952; 06-08-2013 at 11:43 AM. |
thanks for answering
ok.. the problem is.. when I used the versions of windows xp pro sp3 and pro tool 7.4 in my toshiba laptop everything worked normally ... midi sync was fine.. and I could open projects with 20 tracks.. and effects also use the firewire/1934 controller TI (just saying this as a reference)...with the same hardware but different operating system everything was ok.. the problem is that I used.. craked versions of software.. Now I have the toshiba recovery disk ..with win xp home edition sp3 OEM which came with the notebook .. and is not working with pro tool 7 and 7.3.1 which are the versions that I bought with the digi 002 .. I've tried disabling: the wireless..the ethernet.. the via firewire controller.. and everything that I found not necessary..in the Device Manager.. run msconfig disabling services that are not essential to windows.. I read about how to configure windows and pro tool.. I hope someone can help thanks.. |
problem solved! after several attempts ... I found that the problem of synchronizing between click track .. midi sync .. and pro tool 7.3 ... It is solved by placing a usb memory drive before starting pro tool .. Toshiba Satellite A110 digidesign 002 Microsoft Windows XP Home 5.01.2600 (Service Pack 3) pro tool 7.3 .. if you have this problem this is the possible solution .. read the entire post and sandra report to see the hardware and software installed .. |
midi timing erratic even with click on LE 7.3 | Greg F | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 28 | 07-18-2009 03:50 PM |
Click track erratic, transport juddering | marcw8087 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-05-2007 06:05 AM |
Click instrument is erratic! | csselement | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-08-2007 08:46 PM |
Erratic "Solo" Track Functionality | TonyVT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 01-11-2004 09:59 PM |
Erratic Midi Click w/Motu Micro Lite | Oufti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-17-2003 04:12 PM |
