Old 03-20-2012, 06:40 AM
meyoik meyoik is offline
Default Noise elimination/reduction....help!
Hi All, I made a recording (which I can't re-record because it was a live performance) with my input levels too high....and thus, I get a lot of noise background. Is there anybody that can give me a tip on how to reduce it, or eliminate it completely?
Old 03-20-2012, 07:14 AM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Default Re: Noise elimination/reduction....help!
Do you mean it was clipping or distorted?
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 03-20-2012, 07:57 AM
promixr promixr is offline
Izotope RX is really good for this kind of thing... you can try it before you buy to see if it does the trick: http://www.izotope.com/products/audio/rx/download.asp
If you are doing a lot of live recordings in unpredictable situations it might be worth owning:
http://imsproav.com/main/IZOTOPRX2.html
Eddie Sullivan
Long Island Mac Tech
http://long-island-mac-tech.com
[email protected]
631 786 3924
Freelance Mac/Pro Tools tech for hire. Metro New York Area.
Old 03-20-2012, 08:06 AM
It is just like white noise....there is no soundwave, just the white noise of having the mic inputs too high.
Any thoughts on how to fix that?
Thanks for your tip...do you know of any out of the box PT plug-in or PT native feature that I can use to clean that noise?
Old 03-20-2012, 08:26 AM
You can try to reduce it using a combination of gating (AIR Filter Gate maybe?) and some EQ, to try to home in on the problem frequencies, but this could affect the program material undesirably, you'd be in the best position to experiment with this. Something like RX uses a bunch of processes and makes it a bit easier to retain the integrity of the program material.
The best way to start is to loop a section of 'just the noise' and try EQ-ing until you are satisfied with the reduction and then play back the whole file and see how much the plug-in settings to reduce the noise are affecting the whole file- then work from there to adjust things till you get an acceptable balance. (Note: Gating may only really serve to reduce the noise in the silent passages- which may be slightly less distracting to the listener... but it probably won't get rid of the noise in the overall program...)
Eddie Sullivan
[email protected]
631 786 3924
Old 03-20-2012, 10:10 AM
Thanks promixr, I'll give that a shot.
bad lappel noise elimination tips paranerd Post - Surround - Video 7 10-02-2008 11:05 AM
best noise reduction Anibal Pro Tools TDM Systems (Mac) 5 08-05-2007 01:53 PM
Noise Reduction saintkev77 Post - Surround - Video 27 06-04-2007 01:43 PM
noise reduction edwardo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-10-2005 09:32 AM
Noise Reduction Eric G 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-28-2005 04:21 PM
