Old 05-31-2005, 10:43 AM
autopilot autopilot is offline
Default Help Setting up Machine Control 2 in OS X
I've already read through all of the digi material on this and I am still left with some quesitons...
I have Machine Control v2 and want to control a Fostex D-15 over 9 Pin Serial. The Keyspan USA-28x looks like it converts usb to an 8 pin Din but NOT 9 pin Serial. Do I need to buy a special serial cable to go out of the Keyspan and into my DAT deck?
As always, any help and anyone with experience is greatly appreciated....
Old 06-02-2005, 10:32 AM
SFXPost SFXPost is offline
Default Re: Help Setting up Machine Control 2 in OS X
Yes, this is the same setup that we have (although not the same deck). Get the Keyspan USA-28x and then this cable:
http://www.pricegrabber.com/search_g...asterid=433170
and you should be golden.
Holley
www.creativesoundstudios.com
Old 06-02-2005, 12:39 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
The cable is very easily made.
Cut one end off of a 8 pin/8 pin Mac serial cable, and solder a 9-pin (Radio Shack).
Wiring specs can be found in the machine control manual here online.
I've made 3 already.
IMDB
Old 06-02-2005, 08:15 PM
Did Digidesign correct the error in the MachineControl guide? In the printed guide I have, if you make a cable based on their pinouts, it will not work!
Machine Control setting for Sony XD Cam Eric Seaberg Post - Surround - Video 3 08-19-2011 05:39 PM
Help setting up drum machine as MIDI slave cometsincaves macOS 4 08-06-2011 08:31 PM
Setting up Machine Control option on MIX system mrcomber24 Post - Surround - Video 4 02-14-2009 01:40 PM
Setting up Machine Control option on MIX system mrcomber24 Pro Tools TDM Systems (Win) 0 02-10-2009 02:15 PM
Help with setting up Drum Machine jpoprock MIDI 4 08-02-2002 01:40 AM
