Old 01-01-2005, 02:27 PM
theom theom is offline
Default anyone using Behringer BCF 2000 ?
Has anyone tried the behringer BCF 2000 fader control surface?
In general I dont like behringer stuff but, this thing looks good on paper.
Can anyone comment on compatibillity and integration with PT Le?
Thanks,
theo
Old 01-01-2005, 10:59 PM
Default Re: anyone using Behringer BCF 2000 ?
Is it even available yet?
I did a little searching on the behringer support site and found that it does have a "preset for pro tools" and it is supposed to work via usb protocol to the 001, 002 bypassing the midi interface.
Has anyone demo'd one yet?
So cheap! Seems to good to be true.
probably is.
Old 01-01-2005, 11:50 PM
LIMiT LIMiT is offline
Many give Behringer a hard time due to the fact that they steal (by reverse engineering) manufacturing ideas from other companies,..using cheaper parts (and probably labour).
That being said,..the BCF2000 is no different...it works with Protools via a Mackie HUI emulation mode.
The faders interact seemlessly with my 002R/QuicksilverG4/800Mhz/1.25gRAM via USB 2.0 and can be expandable to 16 faders via the MIDI thru port to another BCF2000. The only drawback as of yet is there is no automation writing with the faders ...yet?...I would hope there is a way they could make this work in the near future.
But if you're looking for a good compact easy to use,..fairly sturdy looking controller from protools (..and can switch to differnt plugin setting parameter controller as well...I'm still testing this)...The Behringer BCF2000 gets my vote.
Hope this helps..
PEACE,
LIMiT
Old 01-02-2005, 12:08 AM
So, am I understanding you?
You cant use the bcf faders for writing volume automation? That is the main reason I'd want it.
Drag.
Old 01-02-2005, 01:28 AM
trew trew is offline
Thank goodness Theo,
I'd hate to find out that MY gear guru is using a big beri unit!
Old 01-02-2005, 11:46 AM
HAHHA,
Whats up dude? email me willya.
Old 01-02-2005, 12:48 PM
edwinh edwinh is offline
I have no trouble writing volume automation (and pan and send as well, haven't tried other varieties yet). The real issue is editing automation as there is no touch sensitivity. It's doable, but just a little more effort. For the money, it's hard to beat, but I still lust after a Command 8.
Edwin
2.5 Ghz i7 MBP
16 GB RAM
OS X.11.6
PT 12.6
MH ULN-8 x3
Behringer BCF 2000, does it work with LE8? mercurysoto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 12-17-2011 03:02 AM
Behringer BCF-2000 Question 1150Post 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-04-2006 11:28 AM
Behringer BCF-2000 USB/MIDI controller HELP? afxsguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-25-2004 04:30 PM
Behringer BCF-2000 USB/MIDI Controller HELP? afxsguy MIDI 0 12-24-2004 12:45 AM
likely hood of support for Behringer BCF 2000? martian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 30 03-07-2004 02:43 AM
