Old 09-16-2009, 06:35 AM
Che_Guitarra Che_Guitarra is offline
Default Strike - Mix setting workaround needed?
I'm using Strike across an album, and in a strive for consistency i'm using a personalised 'kit' and 'mix' setting.
I got this custom preset working a charm over four of 15 songs, but now something's gone amiss. Loading my 'mix' preset also seems to be dragging a 'style' preset along aswell. The reggae feel is lost for an unselected rock style.
My plugin settings are saved in the Strike application folder, as per standard default.
Oh yeah, I can't seem to drag 'kit' settings, I have to load from the plugins' top drop-menus... also another interesting quibble.
Can anyone think of a workaround or solution?
Old 09-16-2009, 10:02 PM
Default Re: Strike - Mix setting workaround needed?
Have you changed or altered your system configuration? Can you recover an old session and save the Strike Style to be applied to your current working session?
filosofem
Old 09-22-2009, 10:09 PM
Mefiant Mefiant is offline
Go into your old session and at the top of the Strike window, under PRESET, save your SETTINGS again under a different name x2 or however you want to name it. I suggest you LOCK those settings, then SET AS USER DEFAULT.
Best,
Mefiant
Old 09-22-2009, 11:23 PM
With respect the OP is talking about loading/saving to the Strike Browser not the Plug-in setting.
filosofem
Setting up Axiom-25 with Strike Scott93933 Virtual Instruments 7 07-04-2011 04:46 PM
Missing Strike setting fromthesunset Virtual Instruments 0 01-11-2010 12:32 PM
Strike - Settings >> How do you save a User Setting? edgarbc1 Virtual Instruments 1 01-03-2008 08:38 PM
Strike: Tutoring Needed JKyles Virtual Instruments 0 01-18-2007 08:55 AM
Strike! : Setting BPM ? Light Wing Virtual Instruments 3 10-23-2006 03:16 PM
