Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 03-03-2023, 09:46 AM
VinsonKZ VinsonKZ is offline
Default Carbon S/PDIF Output Invalid!!
Hi!
I am trying to use the optical S/PDIF output on my carbon as the monitor output. I've already set my ports to S/PDIF in Pro Tools. The i/o was also correctly set to "ADAT 1 1-2". However, I cannot get signal output from my carbon with S/PDIF. Instead, ADAT works perfectly, but my monitoring system only accepts optical S/PDIF. Does anyone have experience on using S/PDIF output on carbon? Thanks!
Mac Studio 2022, MacOS 13.2, Pro Tools Carbon, Pro Tools Ultimate 2022.12
Old 03-03-2023, 10:40 AM
BScout BScout is offline
Default Re: Carbon S/PDIF Output Invalid!!
Using it at a studio (it feeds the monitoring chain) and it works perfectly. Are you up-to-date on everything?
Screenshots of the hardware page might help to verify settings.
Pro Tools Ult 2024.10, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface ProS1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 14.7.1RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 03-03-2023, 12:27 PM
Yes, I am running Pro Tools Ultimate 2022.12 with the latest Carbon firmware on MacOS 13.2, Apple Sillicon. What monitoring system are you using in the studio with the S/PDIF input? Actually, I was using a cheap optical to rca converter to run this test cause I don't have other optical S/PDIF devices with me right now. I'm wondering if there are compatibility issues between Carbon and this small converter.
Old 03-03-2023, 12:38 PM
[email protected] msstrickland@fsu.edu is offline
Mostly likely it is the converter. I'm using the Hosa Optical SPDIF to AES/EBU converter on my system without issue.
Old 03-03-2023, 03:19 PM
We run direct (optical out to in). That one goes Carbon to a miniDSP box (and then miniDSP box to speakers)
The Hosa box (ODL-312) has been a solid unit for years for us in other capacities to go from optical to AES. (we use/used lots of those to get Toslink out from Mac Pro 5,1 computers into our monitoring systems.)
Old 03-03-2023, 08:37 PM
Thanks! I will try Hosa converter.
Old 03-03-2023, 08:40 PM
Cool! I will check the Hosa box. Thanks!
Pro Tools Carbon - Is there is a way to send Mon L-R to Output 7-8? Zak7 Pro Tools | Carbon 20 05-11-2022 06:53 PM
Carbon is not -18dBFS like normal HD? Also, how to use S/PDIF? CoreRec Pro Tools | Carbon 13 06-17-2021 05:22 AM
Headphones Output missing in ASIO4ALL, invalid in Windows Audio Device Desande Pro Tools | Intro Discussion 9 10-21-2017 12:11 AM
Output Invalid Path (Using PT( w.out Interface) mikephilson Pro Tools 9 2 07-03-2011 01:36 PM
888 interface's s/pdif input doesn't like AMIII s/pdif output jmark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-19-2001 02:03 PM
