vista home premium sp1 or xp sp3?
Hey all...my proposed new computer comes with vista home premium sp1 and I'm wondering if I should plan on buying xp home sp3 and installing the xp instead...is there a procedure for doing this properly? A follow up question might be should I upgrade the vista home to ultimate for 150.00 more? I know this is addressed in various places but I can't find a definitive concensus....thanks
Re: vista home premium sp1 or xp sp3?
So you are buying an "off the shelf" computer? Have you checked to see that it will work with PT? Pro Tools is very choosy about what hardware it works with and you really need to do your homework on this(which maybe you did already) as you can buy lots of computers that will not work no matter what you do with the OS. Back to your question, I prefer XP SP3 and I would simply buy another hard drive, pull the Vista drive out and do a fresh load of XP. Now there is more to think about here. What size drive is the new Vista system drive? What size audio drive does it have? (you DO know that you need to be recording to a separate hard drive? This can be external on firewire[but NOT USB] or internal[better performance and cheaper]) If the Vista system drive is a reasonable size(160gig is plenty!), then you might think about buying another 160 gig for your XP install. Later on, when your system is working solid, take the Vista drive and install it in an external case(can be USB for this) and use Norton Ghost or Acronis True Image to clone your XP system drive. If you have a crash or some other catastrophe, you can take that cloned drive and install it place of your screwed up XP drive and be back to work in minutes. Lots to think about here......
Of course, you can simply choose to reformat the Vista drive, using the XP install disk.
...and dont forget to check and see if you can actually get XP Drivers for all your computer parts.
As a side note, PT using XP gets around an 80% boost in performance over that horrid OS we call...Vista. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
+1 on Vista 32bit running PT fine. The big thing is that Vista is just not as snappy feeling as a finely tuned XP install, but that is in reference to general system ops. When you're in PT it runs and feels as fast as in XP, and IMO Vista does seem more stable, but you can cause it to crash, but you can do that on the MAC side as well. Shane and the boys are right about XP/PT performance... basically the XP OS uses less Ram, so PT can breathe a little better. A few of us are thrashing Windows 7 with some early positive impressions, though we're only into the basic op issues at this time, later for PT performance tests. |
Awesome support guys! Yes, this is an off the shelf box...Dell xps 420: Intel core 2 Q6600 Quad 2.4 1066FSB...4 GB at 800 MHz...x38...the smallest drive offered is 500GB SATA 3Gb/s 16MB...I'm only getting this because of a great financing promo and appears to be approved by Digi (???) It ships with the ati Radeon HD 3450 256 video card which is an issue for I use a two monitor system currently...any ideas...funny thing, I've been using a Dell 3000 P4 2 GB memory system w/xp home and has been a solid performer with up to 32 tracks...very few plugs no midi....I simply ran out of PCI slots to upgrade UAD (which I like) and upgraded to Pt 8 from 7.3...I guess now is the time to get some more power but I want to do this as painless as possible with good financing...thanks much again for any and all input....
Make sure you have the ability to return the computer in case it's not compatible with Pro Tools. If possible, post a Sandra or PC Wizard report either before you buy or right after so that the gurus can advise if it will work with PT or point out any possible problems.
Also, what Digidesign interface are you using? Cheers,
...002
As you say, Vista is quite solid. But when you start doing large sessions with lots of plug-ins, tracks and VI's you'll find that Vista bogs down much sooner than XP does for the same memory and resource usage. It's not a small amount, either, especially with PT8. Quote:
They have close to equal in RAM requirements at the minimum level (best for PT) assuming you have turned off all the necessary services and eye candy in Vista which gobble up memory. Under that scenario XP uses about 400M for the OS, whereas Vista is closer to 750M which you can usually work around. That's not the issue, though. I prefer Vista too, for the stability, stable drivers and generally smarter operation. I moved from XP to Vista Ultimate a few months ago and was quite happy with it until I started using 96k recording exclusively and in combination with large sessions and VI's -- with PT8. It really bogs down, requiring you to juggle buffers and tweak plug-ins, etc. 1-2 weeks ago I moved back to XP (and can now boot either one with the same PT8 configurations and sessions). The difference is astounding. There is one session in Vista and PT8 that I cannot even play (45 tracks, a few VI's and lots of plug-ins) let alone use low-latency mode for new live tracks. In XP it works flawlessly with lots of overhead, standard size buffers, not a hiccup at all. The *only* difference is Vista overhead. Until you get to the larger and more demanding sessions, Vista will do OK, and be just a little slower for the same CPU. Not usually a big deal until you start pushing. Win7 should give better performance than even XP with an equal or smaller footprint, and be as or more solid than Vista now. We're all looking forward to it! --Bill
Asus P6T DLX, Intel i7-920 OC'd to 3.2GHz, 6GB DDR3-1600 (triple), Win XP Pro SP3, PTLE 8cs2, MPTK2, Black Lion 003R, UAD-2 Duo, UA 2192 Monitoring: 24-bit dig to Avocet Crane Song controller, Pass Labs x250.5 amp, B&K N801 monitors, Transparent Audio analog cabling |
/Micke
I voted at www.deardigi.com Drummer of Yamaha Birch Absolute Custom Nouveau Vintage Natural - Zildjian K Custom Dark - Sabian HH Macbook (2009-01) 2.0 GHz 4 GB Intel Quad (2007-07) Q6600 2x250 4 GB PT 8 Digirack 002 Monitors: JM-Lab Electra 906 & SW900 driven with Pioneer Reference M-90 "Semiprofessional user" |
--Bill
Vista Home Premium 64-bit issues | luckywig52 | Pro Tools M-Powered (Win) | 3 | 09-02-2009 09:10 PM |
Vista Home Premium | CCH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 06-06-2009 05:30 PM |
Anyone Using MPowered 8 On Vista Home basic or Home premium | acq1 | Pro Tools M-Powered (Win) | 0 | 01-13-2009 09:59 PM |
Vista Home Premium to XP Pro on 64 bit PC? | akakpaws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-25-2008 11:53 AM |
7.4 on Vista Home Premium | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-02-2008 11:22 AM |
