Old 10-16-2024, 10:10 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Need help with Reason
I'm currently running Reason 11 in rack mode in Pro Tools. Recently I've needed to go back to some much older sessions I have to resurrect some of those ideas for a few projects I'm working on. Unfortunately, those older projects in which I used Reason are all with Reason in Rewire mode, which we no longer have.
Suggestions on how I can resurrect those? If I can do that and see what I did, I can recreate in Rack mode. Not sure what to do. Help?
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Win-11/PT 2024.10/i9-14900K/Gigabye Z790MB/64GB RAM DDR5
Old 10-16-2024, 10:46 AM
tope d's Avatar
tope d tope d is offline
Default Re: Need help with Reason
Not sure if on Mac or Windows, but have you ever considered doing a dual boot system with one drive running a supported OS and older PT version and the other partition with your current one?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 10-16-2024, 02:13 PM
DonaldM's Avatar
I'm running on Win-11. That's sounds really complicated and I'm not sure I'd even know how to do that.
Old 10-17-2024, 11:56 AM
EGS's Avatar
EGS EGS is offline
Hmmm ... just brainstorming here ...
Before attempting take a boot-drive image backup, like Macrium Reflect or similar. Then, you might be able to co-install Pro Tools 10, and access Reason via Rewire?
Perhaps someone more knowledgeable on this will chime in.
Desktop build: Pro Tools Studio 2024.6 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626
Laptop: Pro Tools Studio 2024.6 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820
Ancient/Legacy (still works!): Pro Tools 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001
Click for audio/video demo
Click for resume
Old 10-18-2024, 07:29 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Open in standalone, save tracks as audio or mixes, midi then import.
Get sessions tempo 1st as older reason version did not save the tempos accross rewire.
Old 10-19-2024, 12:48 PM
DonaldM's Avatar
That might work. Hadn't thought of that approach. One issue I have is the MIDI tracks that played the various Reason instruments are all in PT. But if I know what the modules and sounds were for each one then I can re-create in the Rack. It'll take a bit of work, but I should be able to do it this way. thanks.
Old 10-31-2024, 04:56 PM
innerbooty innerbooty is offline
I've struggled with this conundrum too. I don't believe the Reason folks have accounted for this forward compatability at all, which is super frustrating. Since I still have my old Pro Tools rig on a separate older Mac, I am able to jump back to old sessions. With Reason, I've had to go into the relevant Pro Tools session and save a Preset for each Reason instrument track I'm interested in resurrecting. Then you copy over and load those Presets into the relevant Reason Rack plugin track in the new session. It works, but it's a total PITB. Thankfully I have to do it a lot... Not sure this helps. Requires having an older version of your PT system around..
Mac Studio M1 Ultra 64GB RAM, Pro Tools Ultimate 2023.12.1, Ventura, Apollo x4 / Avid HD IO 16x16 w/ HDX, UAD Octo
Old 11-01-2024, 07:13 AM
DonaldM's Avatar
In my case, I had saved all those older Rewire sessions in Reason by the same session names as the PT session in which I used it. So what I'm doing is opening those sessions in Reason and seeing what Re's were on what channels and what patches, etc, and then I simply load those into the new PT session with Reason Rack and redirect the original MIDI tracks in PT to the new Reason Rack. So far, that seems to work. Takes a bit of time, but gets the job done.
MBOX, Reason 2.0, macbook, pro-tools 7.3 (no reason plug in) tahiti78 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-11-2008 09:11 AM
OT: Reason Drum Refill and Reason 3.0 RAM question Joe Evans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-02-2006 12:34 AM
Will Reason 3.0 Read Reason Adapted Files???? remaofaes Pro Tools TDM Systems (Mac) 2 01-08-2006 01:33 PM
Reason 3.0 and Reason Drum Kit Refill - Opinions? JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 12-19-2005 09:29 AM
Upgrade PT Reason Adapted to FULL Reason ...Price? bluesigns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-09-2003 08:04 AM
