Are you creating a 1 x 8 or 2 x 4 map. S1 vs Dock/Control
I don't understand the question (S1 vs Dock / Control part). I tried creating a Custom Inserts map on the Control app, and those don't translate to the S1, the S1 keeps displaying the default order. EQ Custom map doesn't help as the Dyn Range parameters are not available (although it would be preferable due to the naming of the bands).
However, I figured out an ok'ish workaround, where I have a Inserts Custom map with just the Dyn Range controls (in Control/Dock) as 2x4, when clicking the plugin in Pro Tools this would open the EQ maps on my S1's AND this Custom Map on the Dock/Control (so normal EQ on the S1 knobs and dyn EQ on the Dock knobs) with the "Show EQ/Dyn Plugins on Surface as inserts if there is a custom map" setting on. It worked for a while, but I think I encountered a bug, as this configuration crashes EuCon very often (EuControl app quits and surfaces missing, also PT shows the red light even after a EuCon restart and seemingly functioning surfaces) - possible related to the fact that some of my EQ's don't have the "7 band" preset loaded (but just one HPF) or somesuch (session created before moving to EuCon)? My Custom Map file is here, if you want to test the crashing behaviour out: https://www.dropbox.com/scl/fi/ntun1...jkv8y27jf&dl=0
mikkoraita.com Windows 11 23H2, Intel Core Ultra 9 285K, Asus Hero Z890, 48GB 8400MHz CUDIMM, Corsair RM850x, 10TB of M.2 (Crucial T705 for OS), 22TB of HDD, Noctua NH-D15 G2 and Fractal Design Meshify 2 + RTX 4070 - PT Ultimate 2024.10.2 / DAR 5.3 And Intel i9-14900K, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 Used to be/ Spare/ old DAR: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAR 5.0 HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and Dock + 3x S1 |
There are two map types 1x8 and 2x4. One for the S1 one for the Dock. If you are creating a 2x4 it will not show on the S1. pg 110 https://resources.avid.com/SupportFi...s_v2024.10.pdf
![]() Quote:
Although I already liked my "mixed" workflow using a 2x4 Custom Inserts map on the Dock/Control with the Stock EQ map on the S1's - if it just didn't crash EuCon...
![]() Quote:
#16
![]() Quote:
Edit: Although I'm not sure if it's exclusive to FF (only EQ I've tried it with) or just the "Show EQ/Dyn Plugins on Surface as inserts if there is a custom map" setting.
#17
Can you tell me both the versions of EuControl(Help/About) and Avid Control (gear icon/about). So when you say tyhe whole of EUCON, you mean EuControl and Avid Control or?
#18
![]() Quote:
I'm not in the room so cannot see Avid Control versions until a few hours, but they are the 2024.10 Android versions released last week, the pads have not connected to the internet since. EuControl Windows version (I just checked with remote connection) is 2024.10.0.19. Since writing the last post, I updated Pro Tools from 2024.6 to 2024.10.1 (with the Windows Alt-Tab bug fixed), will resume working with the updated system in a few hours, but I won't try using the Custom Map again before the new EuCon update lands (need to get work done, this EuCon crashing always interrupts the flow).
#19
Avid Control (2 different Samsung tablets, both Android 14 one master, one meter) is 2024.10.0.367.
#20
We tested this here(even with your mapping) and its rock solid. There must be something else at play as many use this plugin and custom maps. Can you right click on the EuControl Icon up top and select collect logs. Then upload them somewhere and PM me a link. Thanks
Also what version of the plugin are you using? One thing to try if you haven't, is using the EUCON installer select remove all apps and remove all prefs. Reboot and Install just the top check box (EuControl) |
Post-C&C Custom Mapping questions | basehead617 | Avid S4/S6 | 7 | 06-29-2021 06:57 AM |
Custom plugin mapping for knobs?? | stefanboman | Avid S4/S6 | 24 | 06-29-2021 06:56 AM |
Custom plugin mapping | marsian | Avid S1, S3, Dock and Control App | 2 | 05-29-2019 07:45 AM |
Mapping to custom faders | dunebuggy | Pro Tools 10 | 4 | 06-29-2015 08:51 AM |
Request for Custom Surround Mapping | mavericksound | Post - Surround - Video | 2 | 04-22-2007 09:51 AM |
