Old 03-30-2023, 04:37 AM
Chevron Chevron is offline
Default Eucon 2022.12.1.34 S1 No Soft Key Colors
I always found this a bit unreliable before, but in the current Eucon I can not customise any Soft Key Colours on the Avid S1.
In Settings > General > Soft Key Color set to Track Color works - albeit a little dark and funky as we have come to expect with darker track colors.
But if I try and switch that setting to Soft Key Colors I get no colors at all.
Pro Tools Studio 2024.3| Eucon 2023.11 | Mac OS 14.3.1 | Soundflow | Streamdeck | 16" Apple MacBook Pro M3 Max 16 Core 64 GB RAM | 2020 MacBook Pro 13" M1 16 GB RAM | Hackintosh i9 9900KS 32 GB RAM
Old 03-30-2023, 12:39 PM
BScout BScout is offline
Default Re: Eucon 2022.12.1.34 S1 No Soft Key Colors
Colours only show up for certain commands only: selectable/toggles. They get lit for when they are toggled on.
It makes no sense but Avid has chosen this inconsistent approach vs doing colors like the Dock softkeys. Dumb choice on their part and not explained in the Eucontol setting so to make it more confusing for users. Bad UI.
Old 03-31-2023, 10:03 AM
EddieJones's Avatar
Not a dumb choice (thanks!) To simplify and improve things going forward we put the softkey code from S6 into EuControl. This already has made some good improvements. You now have a real delay feature for instance. Next release will see multi-DAW macros...and watch this space for Soundflow commands. The fall out which is being addressed and even improved over what it was before 22.12 is that the off-state colors don't show. Sometimes to move forward takes a little time, EUCON code is extremely complicated.
Old 04-03-2023, 01:19 AM
Thanks Eddie, so I understand. It is now normal behaviour for the soft keys to not show Soft Key Colors created in the Eucontrol Settings? Unless for commands that have an On and Off state?
Could you please confirm? And will this return in the future?
Are direct Soundflow commands coming to the S1 too?!? That would be great.
Old 04-03-2023, 09:55 AM
EddieJones's Avatar
Yes and Yes and Yes
Old 04-04-2023, 03:13 AM
Yes and Yes and Yes
Old 04-04-2023, 06:45 AM
TJ Allen TJ Allen is offline
Yes and Yes and Yes
Does this mean there's the possibility of integrating Eucon commands into Soundflow at some point in the future as well? Direct communication both ways would be an incredible system.
Eucon 2022.12 creativecontrol Avid S4/S6 19 02-02-2023 11:21 AM
What versions of Pro Tools 2022 work with Eucon 2022.9 Mixmaster Rick Pro Tools 2 12-28-2022 01:13 PM
Soft keys issues pt 2022 10.0 marmouch273 Avid S4/S6 2 11-14-2022 08:25 AM
Eucon 2022.4 Cheesehead Avid S1, S3, Dock and Control App 9 04-28-2022 08:54 AM
Eucon 3.2.1 Mac OSx 10.8.5 Touch Screen track Colors Cryos Artist Series 1 02-06-2015 07:15 PM
