Control Panel - Sound = Problems
I have had some trouble with the Control Panel. God knows why there are now 2 Digidesign options, of which one the 2nd works (I don't think the 1st one does)...
AND, there are 2 Built In options. WHAT! Juergen |
Re: Control Panel - Sound = Problems
That is not normal. You should trash your sound preferences.
(always make backups!) |
You haven't given your system specs. I would venture to guess that you need to remove the Digidesign control panel on older systems and if you are using 9.x you need to disable the Digidesign Sound Drivers extension (v. 1.42), delete the sound preferences and restart your computer and see if this solves your problem. Good Luck!!
Mh...I already trashed my sound prefs, must have done it a dozen times now. I am sorry for not giving my system specs. Here they are:
G4 400 Mhz 256 MB RAM OS 9.01 (is 9.1 more stable than mine?) 10 GB 5400rpm HD 28 GB 7200rpm HD With a clean install...do I just back up files on my main drive? Or do I back up EVERYTHING, even stuff on my 4 'lil partitions on my audio drive? (that would take a whole bunch of CD-Rs). Thanks for the suggestions! The comp is in the studio, but will try it tomorrow (disabling the ext and trashing pref). Juergen |
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Juergen:
With a clean install...do I just back up files on my main drive? Or do I back up EVERYTHING, even stuff on my 4 'lil partitions on my audio drive? (that would take a whole bunch of CD-Rs). Juergen<HR></BLOCKQUOTE> Well, in theory, if your audio drive (that's what has the 4 partitions) - files are working correctly, you shouldn't worry about it (even though you should backup anyways). As for the clean install, since it's on a different drive, backup the files you know you need (like I said earlier, backup everything if you're in doubt) from the earlier (Previous) System Folder. Then when you have the new, clean system folder you can just drag them over to it. Now, personaly, when I do "Clean Install's", I do it from scratch. I.E.; I erase everything (if I really have that much downtime, I'll re-format, zero all data, and finaly-> ) re-initialize the drive. It's very time-consuming, but it basicly deep cleans the entire drive, mapping out any physicaly damaged blocks preventing anything to be written there (if they exist that is). The great (the downfall= TOO MUCH TIME) thing about doing it this way, is that you have the absolute minimum of fragmentation. So, there's a few ways to do a clean install, but it's up to you what you wanna do.
bill hughes- I made a conscience decision in a semi-conscious state |
Sound Control Panel | stefano manelfi | Pro Tools TDM Systems (Mac) | 0 | 09-28-2003 06:51 AM |
Sound Control Panel & Digidesign CP problems... | Mt.Everest | Pro Tools TDM Systems (Mac) | 2 | 06-06-2001 04:21 AM |
sound control panel | elgrecco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-28-2000 09:09 PM |
001's gone from the sound control panel | paulod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-16-2000 07:33 PM |
No Sound Control Panel in Mac OS 8.5 | gqkelly | General Discussion | 6 | 06-23-1999 12:09 AM |
