Speaker mute,unmute, record track mute,unmute for ADR
Hi Guys,
We are updating our console in one of our Large Mix rooms in which we also do ADR. We used to have a Harrison which had great flexibility for ADR but now have a D Control. The main thing I am looking to find an elegant solution for is when we want to have a listen to a take on the speaker instead of on cans I need a way to simply mute the record channel and unmute the speaker so we don't get a feedback loop. Now the Harrison had soft keys that made this a simple job but I am struggling to find a similar one button push (foolproof) way of accomplishing this. Has anyone any ideas on how to do it? Obviously doing these two things independently is not the option I want as it leaves too much room for error. Thanks Garret
IMDB |
Re: Speaker mute,unmute, record track mute,unmute for ADR
The safest way I have found... is to route it so the record track can NEVER go to the speakers. Because it just takes one feedback blast to really get someone pissed.
The solution I have used in situations similar to yours is to have dedicated playback tracks with no input that go to the speakers just below your record track... takes an extra click to drag it down... but it's worth it for safety IMO.
IMDB |
I would just patch the c'mon speaker outputs B to your headphone amp. When you are on speaker set A, you have sound through the mains and when you are on speaker set B, you are in the cans.
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
I setup GPI triggered mutes via the SYNC HD & a BSS hardware monitor controller.
I've also setup triggered relays between amps/monitors in the past...
"Any experiment of interest in life will be carried out at your own expense." |
Since then, that stage has been redone and the engineer set it up with "Controllermate" with an xkeys usb controller. You can build macros to the buttons with a somewhat user friendly drag and drop programming app. I got it for my studio to automate a few Icon features since I don't have an Icon. "preview", "punch preview", "master solo clear" etc. Very cheap to test it out, was something like $99 for the 8 button with software.
I have a dream that one day Avid will upgrade Pro Tools Markers tracks..... |
I too use the Playback Only tracks.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
At one point in my life, I did this with VCA masters acting as "modes". If I can find my template from way-back-when, I'll post a link for you. Obviously, my routing was specific to that setup, but you can dissect it and make it your own. I used some applescripts (triggered by XKeys/EuCon and FastScripts) to automate setting up the beeps, copying the timecode location, and some other fancy stuff.
Here's a Google Drive download link It's a pretty basic template, and was set up for a 1 mic record session. For traditional ADR, you'd probably want to turn this into a 2 mic session.
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Can you make a muted track automatically unmute only when you solo it? | DJ Hellfire | Tips & Tricks | 7 | 11-14-2015 03:08 AM |
UN-solo track doesn't UNmute the rest unless stop and play again! | Riquier | Pro Tools M-Powered (Mac) | 15 | 04-12-2011 01:29 PM |
possible to mute track and unmute another "linked" | crizdee | Pro Tools TDM Systems (Mac) | 5 | 06-19-2007 06:55 AM |
Mute/unmute latency?!? | marcelloz | Pro Tools TDM Systems (Mac) | 2 | 06-25-2001 02:40 PM |
mute/unmute region command changed? | mixaudio | Pro Tools TDM Systems (Mac) | 4 | 05-26-2001 09:04 AM |
