7.4.2 and rewire-003rack
i had to remove the rewire plug in from the plugs folder before i could launch protools successfully-rewire has never functioned properly on my intel machine- once i did that it reported that the firmware in 003 rack had to be updated. this was followed by several incidents of losing contact with the 003.eventually it settled down.
i haven't even begun to look at the core audio situation- i kind of gave up on it long ago. the only program that has ever connected properly for me-without any problems- is VLC player. i'll continue to muck about this afternoon. 2x3Ghz Quad-Core Intel Xeon/ 5 gigs of ram/ digi 003 rack/default digi plugins-OSX 10.5.3 |
Re: 7.4.2 and rewire-003rack
I am having the same issue. I need to remove the plug in from the plug-in folder and protools will launch. I thought it was one of the compatibility issues with leopard, but still an issue with 7.4.2.
So it might be a different issue all together, hope someone can shed some incite. -Jesse iMac 2.0gHz Intel core duo 1GB RAM OS 10.5.3 PT 7.4.2 003 External Firewire drive (oxford) at the end of the firewire chain.
-Jesse ___________________________________________ |
Pulling the "digirewire.dpm" plug-in file is a symptom of having installed a non-leopard compatible rewire plug-in.. not rewire functionality of Pro Tools itself..
The 2 common ones from the ignition pack are Reason Adapted and Melodyne essential uno... put your rewire plug-in back in the plug-ins folder go to Mac HD > Library > Application Support and pull the "propellerhead software" folder outta there.. If garage band and logic aren't launching, this should fix that too.. Then update those plug-ins to the newest leopard compatible version before launching or installing them again..
If you don't have it backed up, do you really have it? [ Mac Pro 4x2.66 | 3x23" | 5GB | 4x500GB int. - 4x500GB ext. | 10.5.5 | PT8 003R | Command|8 | BM-5A's ] [ Macbook Pro 2.16 | 17" | 2GB | 1x120GB int. - 2x250GB ext. | 10.5.5/XPproSP2 | PT8 Mbox2Micro ] |
re: digi 003Rack | 2224 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-01-2012 11:51 PM |
003Rack+ Driver-Less, PT LE 8 | Superwoodle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-22-2012 05:48 PM |
Moving to PT LE 003rack from M-powered? | fransmo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-17-2010 11:35 PM |
Possible ADAT issues with 003rack+ | royceg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 04-02-2010 12:13 AM |
003rack and latency | davpond | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-01-2007 07:35 PM |
