Clear Selected removes unselected files? 6.4.1MIX
I posted this in the post-forum, but realize I'd like a broader perspective on this as it affects all. I noticed that 'Clear Selected' can sometimes also remove files which aren't selected. In my estimation this could be quite disasterous.
Have many experienced this? Has Digi addressed it? How can one clean-up a session using 'select unused regions'>'clear selected' knowing other files might unknowingly be removed? Any thoughts on this are greatly appreciated. I just moved my MIX system 5.1(os9) to 6.4.1(osX of course), but with a bug like this which will likely not be addressed with MIX's legacy status, I may go back to 5. Thanks |
Re: Clear Selected removes unselected files? 6.4.1MIX
This was addressed in a later version of Pro Tools, but I believe the changes were too invasive for a cs version.
To avoid the problem with 6.4.1, I believe if you "view all" in the region bin before deleting files from disk that you will be ok. Hope this helps. Danny Caccavo Digidesign |
You mean to tell me I can lose files in 6.4.1 unless I visually check all the selected files to be deleted first?My regions list is pretty big sometimes...that would be a total pain.
Sorry if I'm misunderstanding this.If this is true then this is not a good way to leave the last version of this software...I would expect a fix. Chris
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.6.4 Monterey -32 gigs Ram - Carbon - Protools 2024.3 Ultimate |
I have a dual boot g4 with both 5.1 and 6.4. There do not seem to be many advantages to the OSX system with mix apart from graphics. In fact I'm leaning towards using the OS9 more until I upgrade to HD. 5.1 seems more stable for me and at least I can use the Lexiverb.
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3.1 |
Unfortunately it's still happening on 6.9.1 for example.
And please add "select all muted regions" command! At the end of post production I have tracks full of alternative takes and fx. I would like to remove them using a single command, to make a much smaller archive copy of the session. Quote:
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) |
Clear selected clips shortcut not working hd 10.3.2 | dgoodi22 | macOS | 7 | 02-08-2013 04:49 PM |
Clear Selected removes unselected files? 6.4.1MIX | anders | Post - Surround - Video | 7 | 12-17-2005 06:58 PM |
Save Session Copy In removes files from session!!! | Jay Nierenberg | Pro Tools TDM Systems (Mac) | 24 | 11-11-2004 05:25 PM |
Select unused reagons clear selected deleted used | Mark 66 | Pro Tools TDM Systems (Mac) | 5 | 04-26-2004 03:51 PM |
Clear selected problem | gargoyle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-03-2002 03:03 PM |
