Old 12-28-2012, 12:20 PM
isherwoodme's Avatar
isherwoodme isherwoodme is offline
Default Help! Tascam Interface, no Input into PT9!
My MacBook Pro ran PT9 and the Tascam US-800 perfectly, no issues.
My MacBook crashed, so I installed ProTools on my new Windows 8 machine.
The PC stats:
Initially, PT9 wouldn't start because the Tascam buffer size doesn't match PT9.
After some research, I installed the ASIO4ALL driver. Now PT9 starts beautifully with no issues after setting the Hardware to ASIO4ALL instead of the Tascam interface.
I can use ProTools fine ecept that it doesn't recognize all the Tascam interface inputs. ASIO4ALL allows 30 inputs, but the Tascam only has 8. I assigned them in the I/O dialog.
I created 8 new mono tracks, which assigned each input to its own track. Tried several recording sources through the interface with tracks enabled for recording. No joy.
I can only get 2 inputs to see any signal, 1 & 2.
One more screenshot, the ASIO4ALL settings:
Anyone have any suggestions as to how to get the additional interface inputs to function?
Thanks in advance!
Keep In Tune!
isherwoodme
| 2022 DELL Windows 11 - 64G RAM
| Pro Tools Studio Perpetual & Active Sub
| TASCAM US-16x08
| TASCAM MH-8
| TASCAM US-1x2HR
| '78 Fender Jazz Bass FRETLESS
| '97 Squier P-Bass
| '00 5-String Squier Precision Bass Standard
| '20 Squier Contemporary Active Jazz Bass HH
| '20 Ovation CE48 Celebrity Elite Super Shallow
| '21 Squier Stratocaster - Sienna Sunburst with Maple Fb
Old 03-30-2015, 06:06 AM
Default Re: Help! Tascam Interface, no Input into PT9!
More than 2 years later and still having this same issue with PT 11.3.1.
The TASCAM US-800 interface works perfectly with other DAWs, just not wih PT.
I know upgrade is the easy option, but I hate to throw away 6 good multi-use inputs XLR/TRS, when new 2- and 4- input interfaces are running $300 or more.
I am not using the SPDIF inputs, but there's still 6 that work in other DAWs on the same computer.
Keep In Tune!
isherwoodme
| TASCAM US-16x08
| TASCAM MH-8
| TASCAM US-1x2HR
| '97 Squier P-Bass
Old 07-12-2021, 11:28 AM
I am only replying for posterity - or in case anyone else has this issue.
The reason that the TASCAM US-800 interface won't work with PT in Windows is because PT is looking for standard buffer sizes. The US-800 has non-standard buffer sizes, starting with 192. Apparently the Apple system translates that into something PT can understand, but on Windows it's a no.
Keep In Tune!
isherwoodme
| TASCAM US-16x08
| TASCAM MH-8
| TASCAM US-1x2HR
| '97 Squier P-Bass
Help with I/O Assignment for Tascam US-800 Interface maxspl Pro Tools 9 3 01-20-2022 07:44 PM
New Tascam interface UH7000 nst7 General Discussion 0 03-14-2014 07:58 AM
tascam interface compatibility krecneps macOS 0 10-06-2012 10:32 PM
Interface for Tascam Mixer Alagu Post - Surround - Video 0 01-12-2001 07:55 PM
Tascam USB Interface? TimNielsen Digidesign Hardware & Software 1 12-04-2000 08:29 PM
