Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 06-01-2021, 10:40 PM
MixerGuy MixerGuy is offline
Default Pelican Air 1535 (no foam) hold a Carbon (at an angle)
Hi all
any chance anyone has a Pelican Air 1535 (no foam) case and is using it to carry around a Carbon (at an angle)
the interior (no foam) of the Pelican Air 1535 is: Interior: 20.4" × 11.2" × 7.2"
Avid Carbon = 19” x 13.5” deep x 1U (1.75")
Yes i'd need to angle the Carbon to make it (hopefully) fit, and would pack soft clothing all around it, and would carry on only, not checked luggage.
https://www.amazon.com/Pelican-1535-.../dp/B08C9SPDDP
UPDATE - the hypotenuse on the Pelican 1535 = 13.31 inches (too short for carbon i think)
Old 06-04-2021, 01:18 AM
darkwavo darkwavo is offline
Default Re: Pelican Air 1535 (no foam) hold a Carbon (at an angle)
I would also like a carry on case that could hold the Carbon.
Any other models that would work ??
Old 06-04-2021, 04:21 AM
What about this:
https://www.pelican.com/us/en/produc...u=1560-000-150
same external dimensions as my carry on luggage ive been using for years...
Old 06-04-2021, 07:08 AM
Sardi Sardi is offline
Does it need to be a Pelican case?
If it’s carry on luggage, it probably doesn’t need to be in a Pelican style hard case.
Why not look at those foam padded bags? Rockville and Gator make them in all sorts of configurations. 1RU, 2RU etc. Some have an aluminium frame inside the foam.
That’s what I’d do. Hell of a lot lighter, compact and I think would be durable enough as carry on luggage. Probably wouldn’t throw it in as checked baggage though.
Old 06-04-2021, 07:28 AM
Originally Posted by darkwavo View Post
What about this:
it is quite a bit (4") too thick - as *exterior* is 22.07 x 17.92 x 10.42 inches - i dont think it would fit in an overhead bin.....
TSA USA carry on max: 22" x 14" x 9", which includes*the handle and the wheels.
you might get lucky, but you might have to gate check it.....
also international carry on size is a little smaller... i believe.
also the Carbon is 13.5" deep - do you think it'll fit, even at an angle?
Old 06-04-2021, 07:32 AM
yes, an option
however sometimes the plane overhead gets full before you get on the plane, then you HAVE to gate check your carry on bag, and good luck with a Carbon interface in a lightweight rack bag.... it is pretty likely to get bent / damaged / etc.
Old 06-04-2021, 08:11 AM
This too:
http://www.skbcases.com/industrial/p...s#.YLpBQ5MzbOQ
Ive toured for years and years with this carry on:
https://www.scaliagroup.net/rimowa-s...tte-black.html
And I have almost never had to gate check it.
You can also tell the gate agent you have fragile audio gear and they will usually make sure you can get it on.
Old 06-04-2021, 08:16 AM
also this:
https://www.gatorcases.com/products/...r-rackbag-4uw/
Avid S3 w/ Custom Pelican Case remotedude Buy & Sell 0 02-13-2021 03:51 AM
Custom Pelican Case for Avid S3 remotedude Buy & Sell 0 03-21-2017 06:35 AM
Need help! Express Card, 003 Rack and Dell 1535 star-boy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-19-2011 03:44 PM
Digi002 Case, Pelican, Anvil? Slipcover also bobbybooey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-05-2004 09:48 AM
