Old 02-20-2003, 01:44 PM
stoogee stoogee is offline
Default Group compression
Hello,
Im from the Cubase SX forum, just thought I'd have a snoop at what PT6 is offering. I've had a look at ProTools, but Im wondering if its like Cubase in that you can view all teh groups as faders and then apply FX to groups, like you can in cubase. So far all Ive seen in PT is you can group faders together and they move together.
Also when will PT6 LE for XP be available?
Stoo
Old 02-20-2003, 02:04 PM
accession accession is offline
Default Re: Group compression
Yes, you can apply plug-in effects to a 'sub-mix' of several tracks by routing their outputs into the input of an Aux Track where the plug-in is placed (and then route the output of the Aux Track back into the main mix).
I assume that's what you wanted to know.
Phil
Old 02-20-2003, 03:09 PM
does this then limit your tracks? and if its stereo would it take 2 of the 32 tracks?
Stoo
Old 02-20-2003, 03:13 PM
Slim Shady Slim Shady is offline
No, an aux track does not count as an audio track. Only tracks with actual audio data on them (aka audio tracks) count against the track limit.
Old 02-21-2003, 09:00 AM
Morningstar Morningstar is offline
Stoo [/QB][/QUOTE]
See the big sign that says MAC forum...
Simplfy
group compression setup - webinar help Jeff Pelletier VENUE Live Sound Systems 4 02-07-2013 05:00 PM
Drum Bus/Group/Compression Routing Questions Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 08-13-2012 11:40 AM
1 track in group isn't responding with group! gregwor macOS 7 01-25-2011 07:22 PM
Group Persists for Resizing Even When Group Turned Off. holden Pro Tools TDM Systems (Mac) 3 06-24-2008 03:31 PM
Group buy ... Even Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-15-2005 01:51 PM
