Soundminer 3.2LE & Protools 7
Hey, I'm a new user trying to figure out how to sync up Soundminer and Protools in OS 10.4.5
My first problem is that core audio only seems to allow one audio program to run at the same time (i.e iTunes, Protools, Soundminer). The big problem is that I can't audition sounds in Soundminer while Protools is open. Is there a way around all this? -Lyle at The Argot Network |
Re: Soundminer 3.2LE & Protools 7
You need to install the rewire components so you can monitor through ProTools.
In ProTools you have an AUX track with the input being the Soundminer Engine. |
Jim is correct Soundminer does not work with CoreAudio.
That is explained in the begining of the manual and quickstart that comes with it. If you need to call Soundminer for help, and you get Steve, you had better have read the manual first!!!!!! Its pretty comprehensive, and will answer all your questions.
IMDB |
I understand that you can't go through the PT hardware with out using rewire but I do believe that there is not a problem going through core audio as long as you don't have PT hardware as your core audio out put. I use SM and PT all the time and I'm not using rewire. I have an Igniter card and have that as the system output. A friend uses the built in audio and also has no problem playing SM and PT at the same time.
Just another way to do it! Good luck, S.
IMDB |
Soundminer works fine with Coreaudio and most CoreAudio interfaces. The issue is that Pro tools does NOT allow its CoreAudio driver to be engaged if Pro Tools is running. However, as alluded to in one of the posts, you can use SM through PT hardware via CoreAudio when PT is NOT running. Otherwise use Rewire or you do as Stuart P pointed out. If you have a second CoreAudio interface like the M-Audio, Igniter, MOTU box or the like, you can route SM's output there using Coreaudio.
All the above is true, but beware that using Rewire will cause your pro tools session to crash when quitting Pro Tools. You can save your sessions with no problem, but when you quit Pro Tools for the day, you will get an "unexpected quit" window. This is a known problem with Pro Tools 7, and it seems to cause no harm at all with Pro Tools or your session, it's just kind of scarry!
Michael McDonough, M.P.S.E. Michael McDonough Sound Design |
Like most fx users I have to use em both at the same time so I have to route the SM out via usb/UA25 to get around this for the time being. There is a function in SM the "eye"at the bottom that drops stuff at the insert point, which is really slick and fast. However the Rewire in PTLE on tiger will crash PT. This is also a digi problem that needs fast fixin'!
Dick Maitland C.A.S. |
ProTools Edit Window Disappears With Soundminer Spot to Timeline | chadjhughes | macOS | 1 | 02-25-2014 06:51 AM |
Soundminer and ProTools workspace | eurovision | Post - Surround - Video | 5 | 01-26-2011 01:20 AM |
Soundminer v4.1.8.27 not playing back in protools 8 | digartisan | Post - Surround - Video | 6 | 06-20-2009 01:38 PM |
Soundminer crashing ProTools on Mac OS10.3.9? | muselemuse | Post - Surround - Video | 3 | 06-04-2005 12:22 AM |
