Laptop Soundcard Sample Rate Greyed-Out, Can't Change?
Pro Tools Studio 2022.12
Dell Inspiron laptop - 12th Gen Intel® Core™ i7-1255U Audio Controller: Cirrus CS42L42 (Cirrus Logic High Definition Audio sound card) Driver: Cirrus-Logic-High-Definition-Audio-Driver_78XG8_WIN_10.0.7.39_A01 Windows 11 Home Version 22H2 OS build 22621.963 Feature Experience Pack 1000.22638.1000.0 I am hoping to successfully run Pro Tools on this laptop, and resolve this issue... any suggestions welcome... The sound card sample rate dropdown menu is greyed out, and can't be changed... (it's set to 16 bit, 48000 Hz) Pro Tools can select the Windows audio device, and can play a 16/48 session through the onboard speakers — but no other sample rates are available. I've tried ASIO4ALL, and Pro Tools can select it, and other sample rates are available, but so far it's unable to access onboard speakers... I've tried driver re-installs and most settings changes I can think of, with no luck yet... Last edited by taylor4814; 01-05-2023 at 11:12 AM. |
Re: Laptop Soundcard Sample Rate Greyed-Out, Can't Change?
Pro Tools and Windows audio do not play well together. Your laptop sound device is being controlled by Windows, so whatever sample rate it is set to is what PT will be forced to use.
If you plan on doing any serious work in PT, it is strongly recommended to get an ASIO compliant external audio device. This way, the device will be exclusive to Pro Tools and you can freely set the sample rate as you wish. |
Thanks- yes, typically that is how I have my main machines set up. On this laptop, I'm trying to see if a change is possible, as I've seen it's possible in some cases...
Buy an interface. And make sure Windows isn’t using it as the default sound device.
Yes, that is my typical workflow...
Sample Rate Greyed out in PT12? | weezerboy | Pro Tools 12 | 3 | 12-31-2015 10:53 AM |
Sample rate greyed out? | sw rec | Pro Tools 11 | 5 | 11-05-2013 06:07 PM |
Sample rate greyed out and stuck on 44.1 kHz | pzykt | macOS | 1 | 06-01-2013 04:30 AM |
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! | Nickford | Windows | 0 | 05-26-2013 11:20 AM |
how to change sample rate?? | remains | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-28-2002 04:38 PM |
