Avid Artist Mix not being recognized by any EUCON enabled application
Our Avid Artist Mix board is not being recognized by Pro Tools (version 11.2.1) or Logic X. EuControl sees the board, and it is linked under My Surfaces in EuControl. I have verified that the board is pulling a valid IP, and it is on the same subnet as the workstation it is linked to.
In Pro Tools, I have verified that Enable EUCON is checked under the Ethernet Controllers tab in the Peripherals option. I am not sure what else to check. The board was recognized up until yesterday, and no configuration or software updates had been applied to the workstation before the EUCON enabled apps lost connectivity. |
Re: Avid Artist Mix not being recognized by any EUCON enabled application
What version of OS X are u running ? There were known issues on 10.9.4 but don't know that they were resolved or not.
How do you know it's a valid ip? How about trying a static ip just for fun?
Press both page buttons, it shows the IP the board picked up from the DHCP server. The IP shown is in the correct range and is on the same subnet as the workstation. I have tried a static IP, but it didn't change the issue, so I went back to the DHCP default. |
I don't know if this will help, but I have found that some Eucon connection issues seem to be fixed by changing the IPv6 setting on the network adapter to 'local only'
Shane
OSX 10.11.5, PT 12.5, iConnectAudio4+, Axe FX 2 XL+, Music Man Majesty |
Avid Artist Mix Series Eucon 8 Fader Studio Audio DAW question | shamanrock | Pro Tools 11 | 3 | 03-07-2014 11:56 AM |
Artist Mix with Eucon 3 very sluggish | mrtomcat | Artist Series | 0 | 10-02-2013 11:43 PM |
Avid Artist Mix Eucon - Switching between Layouts | silentmoon | Artist Series | 2 | 03-09-2013 07:42 AM |
just add new avid artist mix = eucon problem ! | klyg | Artist Series | 8 | 05-08-2012 02:29 AM |
