Old 11-22-2010, 06:02 PM
necjamc necjamc is offline
Default Re: The Current Playback Engine Does Not Support a Sample Rate of 48Khz
Kudos to you. I had similar issues but couldn't figure out what I did to get it to work. I do know on my laptop I had to disable the sound card in windows to use it for PT 9, but that was the onboard sound card.
Old 08-17-2012, 09:29 AM
RichrdC RichrdC is offline
justus1900, I know this is an older post, but I'm having this issue with PT MP 8.0.5 on a Windows 7 laptop.. Worked a couple hours in a Mastering Template I made up, and after doing a mix on the next session, I went to open the Mastering Template only to get the message " Playback engine does not support sample rate of 96kHz" If you're out there Justus1900, you mention you unclicked two Tabs in the Sound Engine for Windows 7, rebooted, and all was well.. Might you direct to the tabs you were talking about? Also, could there be a setting in the session I was mixing before I went to open the Mastering template that could cause this to happen? Thank you, Richrdc
Old 08-17-2012, 11:53 AM
Top Jimmy's Avatar
What he did comes down to not using your interface as the native audio I/O for Windows. This has always caused conflicts because the various driver types (ASIO, WDM, MME, DirectSound, WASAPI) do not play well with each other. So if you want to successfully use your interface with Pro Tools, you need to make sure it is not selected as the default Windows audio device and it is also not currently being used by another program.
James Cadwallader
Mac Studio, 64GB RAM, 1 TB SSD, Glyph 2TB USB3 HDD, OWC drive dock, Mac OS Monterey 12.6.2
Pro Tools Ultimate 2022.12, HD Native, Focusrite Red 8Pre
Old 10-23-2012, 12:03 PM
rosannemac rosannemac is offline
Hello there, justus1900,
I'm having the exact same problem. Which forms did you unclick in your system to get it to work?
Appreciate all help I can get.
Old 10-23-2012, 01:45 PM
justus1900 justus1900 is offline
OMG that was two years ago with Pro Tools 9 I am now on Pro Tools 10 and 2 years smarter with Pro Tools which means if it aint broken I dont fix it, I dont remember what I did 2 years ago, I know I went Control Panel --> Sound. selected the interface when I saw it and clicked on something until it worked sorry, I just dont remember and IM in the middle of a HUGE 99 track Mix right now so IM not going to mess with my system and try and recreate the problem and fix it, plus I dont even use the M-Audio Profire 610 any more I use a M-Audio Fast Track C600 USB interface now so I might not be able to recreate anyway.
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell 5750 Precision Workstation
OS: Windows 11 Pro 64bit
CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz,
Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC
OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD
Focusrite Scarlett 18i20 3rd Gen
AVID Pro Tools 2022.12
JBL LSR4328P 8"
JBL LSR310S 10 inch Powered Studio Subwoofer*
Yamaha HS50M Studio Monitors
Alesis Elevate 3 Studio Monitors
M-Audio Axiom 61 Midi Controller
[IMG] code is Off
Current Playback Engine does not support sample rate sharpo07 Pro Tools 11 7 01-08-2016 05:32 AM
The current playback engine does not support a sample rate of 48 kHz. allegrarc macOS 9 11-27-2014 09:43 PM
the current playback engine does not support a sample rate of 47.9 kHz mikevarela Post - Surround - Video 3 03-30-2013 09:26 AM
The current playback engine does not support a sample rate of 192k Oblivious74 macOS 3 06-01-2011 07:08 PM
The current playback engine does not support a sample rate of 44.1 khz murdafew Pro Tools M-Powered (Win) 4 05-14-2010 03:21 AM
