Old 08-28-2010, 03:03 PM
HB1978 HB1978 is offline
Default I see no signal but I hear a sound.
When I audition a vocalist to observe his/her levels while playing back all the instrument tracks I see no signal for the vocalist. When I audition a vocalist while no instrument tracks are playing back I see a signal for the vocalist. What's going on here? I want to see a signal for the vocalist in both scenarios. Can anyone help?
i5 processor, win7, PTLE 8.0.4, Mbox2
Old 08-28-2010, 03:21 PM
Default Re: I see no signal but I hear a sound.
You have Auto-Input monitoring set(which is usually the way you would work). Alt-K to toggle to Input-only monitoring>set your levels(just into the yellow), then switch back to Auto-Input for recording and punch-ins.
Option 2-just go ahead and start recording>set you level>hit STOP and immediatly hit Ctrl-Z(that will undo the recording and delete the new audio permanently).
Old 08-28-2010, 03:55 PM
I tried Input-only and Auto-input monitoring both but every time I press the play button the signal goes away yet I can still hear sound.
Old 08-28-2010, 04:06 PM
Sorry albee1952. You were right. The problem was that I had the track in mute. But the new problem now is I get an echo. How do I stop that? By the way thanks for your help.
Old 08-28-2010, 08:06 PM
The Weed's Avatar
The Weed The Weed is offline
Use the Mix Knob.
Lower your Buffer.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-29-2010, 12:35 AM
Tritono9 Tritono9 is offline
Just a quick question. How I can enable the Auto-Input monitoring?
To listen the signal of one track, I need to arm it to record, no other way to listen the signal without that. If I press Alt+K nothing happens (but a green light turns on). Is there a option to hear the signals without needs to arm the selected track? Thank you!
Multidimensional
Old 08-29-2010, 07:07 AM
What you are doing is correct, but it counts on a couple of other details at the same time. If the track is muted, that over-rides everything else. And, the MIX knob is always in play to some degree. If your computer will handle the load, set the buffer to 128 and the MIX knob all the way to Playback. That should make the latency liveable. This is the main reason I try to encourage folks to go with the firewire interfaces. They simply work better for serious types. If you are wrestling with punch-ins, it would probably be more efficient instead to create new playlists and record several passes; then use the track comping feature(assuming you have PT8) and build a good comp. I think that will be easier than fighting the Mbox shortcomings.(actually, its not the fault of Mbox, specifically, this affects most any USB audio interface due to the speed of the USB bus).
Can hear sound but no signal level - weird? wanaku Windows 12 01-11-2012 08:33 AM
Should I hear signal with pre turned down? Idahoguide 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-09-2009 05:00 PM
I can see the signal but I can't hear my keyboard? producermandan66 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-01-2007 09:51 AM
Can't hear MIDI signal firstbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-18-2005 07:31 PM
synced with pro tools- see signal, but can't hear signal- HELP!!!! hitwriter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-30-2002 10:08 PM
