6-Track BWAV from Logic not recognized by PT
why does PT not recognize an interleaved BWAV (L,R,C, LFE, Ls, Rs 24bit 44,1kHz) from Logic audio? QT and Soundminer read them fine. Thanks, Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: 6-Track BWAV from Logic not recognized by PT
Might be a Microsoft WAV Format Extensible - I think Pro Tools still has a problem with these.
Pete |
Thanks,
I´ll spot them with Soundminer. It reads them fine. Frank.
Sound Forge opens them (and anything else!) no worries at all. You can then export the files as whatever you like.
IMAX DTAC files use these (16Bit/44.1kHz 6 track .wav/interleaved BWF). Sound Forge 9 for Win and Peak Pro 6 for Mac are two applications I can't do without for all that stuff. |
This sounds to simple, but I'll ask anyways. Does the Import Audio function not do the trick?
Then view the region with the original TC stamp for spotting. Ted |
The reason is: PT doesn´t suport the SMPTE track layout. No way around it other than using third party software to convert.
frank.
This is easily fixable.
A few years ago Digi did not support B-Wave. Now they do. Any track config should be fine. A true multichannel wave file should also be playable in it's native format ala Nuendo and others. Digi needs to get it back on "the list" Hey digi mods... any thoughts here? |
Fast Track Pro not recognized | lDuff | FireWire & USB Audio Interfaces (Win) | 2 | 08-24-2013 09:03 AM |
M-audio Fast Track Ultra not recognized by M-powered 7.1 | marcz | Pro Tools M-Powered (Mac) | 1 | 10-16-2009 01:26 PM |
wav not bwav | antonis | Post - Surround - Video | 7 | 09-02-2009 09:00 PM |
HELP protools wont recognized fast track | kikitam00 | Pro Tools M-Powered (Win) | 1 | 12-20-2007 09:41 AM |
PT, AVID,OMF and BWAV ! ? | Pentium | Post - Surround - Video | 1 | 10-02-2005 10:07 AM |
