Old 01-21-2004, 09:15 AM
bannerj bannerj is offline
Default SPDIF
yes, yes...lots of questions.....
I am working with an mbox but would like to track more than two channels. My friend has a metrichalo box that has some 8 mic pres.
Can I run the metrichalo through my mbox using SPIF?
What kind of cable do I use? Will regular RCA work?
Will Protools then recognize all the new inputs?
Is there any documentation on the necessary config of hardware and software?
Old 01-21-2004, 10:02 AM
Slim Shady Slim Shady is offline
Default Re: SPDIF
No, SPDIF only supports 2 channels - no matter if you go analog or digital you cannot record more than 2 channels at once with the Mbox.
ProFire 2626: SPDIF COAX & SPDIF OPTICAL Simultaneous success!!! WHAAAA HAPPENED??? cueball73 macOS 0 05-22-2012 12:41 PM
mono like sound from spdif out (GA-EX58-UD3R) to spdif in (Omni ) chrisdee Pro Tools HDX & HD Native Systems (Mac) 9 04-02-2012 05:10 AM
Spdif RCA to Spdif Optical conversion - degradation?? Hollow Body 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-17-2011 08:21 AM
Digi 96io - can you mix Optical SPDIF and phono SPDIF? buckaroo Pro Tools TDM Systems (Mac) 1 08-24-2009 11:20 AM
Echo Mia W/ SPDIF also does RCA style SPDIF cause the same crashes as optical?? Paul_m 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-16-2003 05:41 AM
