Old 05-02-2002, 04:49 PM
citi citi is offline
Default My system is maxing out! Please Help
I am running a pretty track heavy song 22 or so with plugs. 1 C4 (vocal aux insert), 1 true verb stereo (aux), some delays, and comps. etc.
A couple of says ago I was mixing the session. I tried to drop one more c4 on and BOOM too many plugs, blah blah blah. So I removed it and bounced to disk just fine.
Last night I went back to the very same session and started playing the song. BOOM too many plugs, blah blah blah. What the hell happend and how do I get back to when it worked. Does this something to do with my cache? Also, I read about turning off virtual memory. Mine is still on. If I turned it off could I stretch my plugin count a little. Any advice is welcome.
I still have automation to do and I really need a couple of more plugins without boucing down.
I am running P3 866, 512 ram, Intel 815e board. Two HD (40, 60).
CiTi
http://www.checkonet2ent.com
Old 05-02-2002, 04:57 PM
J. FO J. FO is offline
Default Re: My system is maxing out! Please Help
make sure nothing more than explorer and systray shows up when you do a ctrl-alt-delete. well, those and PTLE. this may help a bit. you might want to also adjust your CPU usage. i think default is 65%. you could try bumping this up? make sure you're running cool too. try taking the a side off the case.
Jeremy Forbis
Old 05-02-2002, 05:03 PM
Xman Xman is offline
<font size="2" face="Verdana, Arial">...with your processor speed try to set the CPU-usage to 80% ...85 may be a problem for windows which can result in "blablabla was held of for interrupts for too long,,," errors..
Old 05-02-2002, 05:04 PM
Right now I believe I am running at 85%. There is nothing on my sytray, but I did not check the temp. I will remove the panel and see if that helps.
CiTi
Old 05-02-2002, 05:07 PM
By the way...do you recommend that virtual memory be turned off? Also, I may be in idiot, but where is the buffer adjustment setting at. Are they the 1 - 5 check boxes? I just could have swarn there was another section.
CiTi
<font size="2" face="Verdana, Arial">try to reduce to 80%
Old 05-02-2002, 05:09 PM
8mmOverdose 8mmOverdose is offline
<font size="2" face="Verdana, Arial">turn off virtual memory and see if it helps. if it doesnt, you can always turn it back on.
Old 05-02-2002, 05:10 PM
<font size="2" face="Verdana, Arial">no need to turn off virtual memory.. if you in mix set you HWbuffer to 1024 you'll find it under Hardware-settings... not the 1-5 DAEbuffersize..
Old 05-02-2002, 05:11 PM
Okay I will lower it to 80...I did notice I am getting very slow redraws now also. Maybe by lowering it my video card will work more efficiently.
CiTi
Old 05-02-2002, 05:13 PM
Originally posted by Xman:
[QBif you in mix set you HWbuffer to 1024 you'll find it under Hardware-settings... not the 1-5 DAEbuffersize..[/QB]
<font size="2" face="Verdana, Arial">that's what I was looking for...thanks. I will try that when i get home.
CiTi
Maxing out an HD3 Rig Titans55 Pro Tools TDM Systems (Mac) 5 11-26-2010 12:00 AM
CPU Maxing out taXe Pro Tools M-Powered (Win) 5 11-08-2009 04:35 PM
maxing out my system resources Azure DC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-08-2007 05:02 PM
Maxing out cpu on laptop with 7.0 Driveteam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-22-2006 09:14 PM
OT: Could I be maxing out my system RAM-wise? xeetstreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-24-2004 10:30 PM
