Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 06-01-2021, 07:22 AM
millca19 millca19 is offline
Default Unable to create a new project
I've only just downloaded Pro Tools First and have no idea how to use it. I think I've installed all the necessary software...drivers etc. I'm using it with an M-audio Duo USB-interface. When I try to create a new project, it comes up with an error message: "Some inputs or outputs have become inactive because your audio hardware device has changed. Some inputs are missing". I'm quite confused. Also, I'm unable to find my system ID: under the Pro Tools product information, the only one that comes up is my iLok ID? That's why I can't phone support or send in a case.
I would appreciate any advice, thank you!
Old 06-02-2021, 05:30 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Unable to create a new project
Hi, What operating system are you using? Do you know what you have selected for your Playback Engine? Help Us Help You
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 06-03-2021, 07:31 AM
2 things to help(hopefully).
1-If you can open PT, go to Setup>Playback Engine and select the M-Audio unit to be the "Playback engine"(if its not available on the menu, try re-installing the driver or moving the interface to a different USB port). OR, hold the SHIFT key while opening PT as that will take you directly(eventually) to the window to select the "audio engine"(in either case, once you change this to the M-Audio box, PT will need to restart).
2-don't create a "Project". Instead, create a "Session". Why? Because projects live in the cloud, which can be unreliable. Sessions live on your hard drive.
Unable to create any project Lionthatch Pro Tools | Intro Discussion 9 09-18-2019 12:45 PM
Can't create new project downwardheavenward Pro Tools | Intro Discussion 1 10-04-2018 02:51 PM
Unable to create project stevo999 Pro Tools | Intro Discussion 2 02-16-2017 01:54 AM
Create Project vs. Create Sessions metalmixer Getting Started 2 09-12-2016 08:55 AM
Create New Project - There was an error posting the project. descendant Pro Tools | Intro Discussion 13 04-24-2016 06:35 PM
