Old 05-04-2021, 04:57 AM
midnightrambler midnightrambler is online now
Default Re: Consolidating clips causes distortion
Originally Posted by BLG View Post
I did adjust clip gain (to +9.5dB), but why should that matter when it sounds fine before consolidation?
You've pushed the file over 0dBFS. When you play this back through the 32 bit floating point mixer, it has enough headroom to cope, when you consolidate the clip to a 24Bit file, it doesn't.
Old 05-04-2021, 09:08 AM
BLG BLG is offline
I don't really understand how/why that's happening. If you have any links or things I can search for that would explain that I'd appreciate it.
So how come when I commit the track (which consolidates it as well) the problem goes away?
Old 05-04-2021, 12:05 PM
Farhoof's Avatar
Farhoof Farhoof is offline
Commit is by default using 32bit floating point files, which can go over 0dBFS. You can change this in the prefs to your session settings.
Old 05-04-2021, 01:05 PM
BLG BLG is offline
Thanks for the explantion!
Old 05-06-2021, 03:48 AM
“These files can go to 11” (etc)
  #16
Old 05-06-2021, 01:29 PM
daeron80 daeron80 is offline
After opening his mp3s in RX, I doubt that's the problem. Unless he brought his master fader way down before bouncing or something. His peaks are well below full scale.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
  #17
Old 05-06-2021, 04:58 PM
PMF Media PMF Media is offline
Not sure if this is YOUR issue but I've seen this with other users several times and it can be a bugger to come to terms with, essentially you may have inadvertently zoomed the waveform out and then at a later point seen the reduced amplitude of the file and done some "gain staging" to bring things back up to a more optimal level, everything will sound fine until you consolidate the file and see the resulting waveform clipped and squared off, as already mentioned, internally the 32 bit float makes it almost impossible to achieve distorted signal... until you consolidate and create a new file which is now actually quite a bit hotter.
As I said, not sure this is the issue at hand but worth a look, a quick way to reset the waveform zoom to default is ctrl/opt/cmd/[ (this is on a Mac) or option/a to zoom to entire - which will also work to reset the waveform zoom.
Good luck.
  #18
Old 05-07-2021, 02:26 AM
Basically the moral of the tale is *turn everything down*
  #19
Old 05-07-2021, 11:44 AM
Used to. Currently it clips at +20 dBFS. There's a thread about that bug, too.
David J. Finnamore
  #20
Old 05-07-2021, 11:47 AM
Rich Breen Rich Breen is online now
Yes, exactly - unless this has been pulled down after the consolidate these files are at a very safe level. Something else strange going on with this. Would like to see the original files/session to see what's happening.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Commit always consolidating clips? bing181 Pro Tools 12 20 06-01-2022 07:43 AM
12.8.1 bug: PT flips L/R channels when consolidating stereo clips in timeline Swedish Pro Tools 12 11 10-08-2017 01:23 PM
Commit always consolidating clips? firosiro Pro Tools 12 1 09-28-2017 12:52 AM
Consolidating Clips/tracks Tampaguitar Pro Tools 11 9 12-20-2013 11:33 AM
consolidating clips correctly..pls..help... chal7ds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-14-2005 12:22 PM
