Is 44.1 Khz 24-bit Good For a Standard Music Session With This PC?
I'm still learning things with Pro Tools everyday, and as many of you know, I have read an article on the debate of 44.1 vs 48 vs 96 and so on.....
Here is the article, it is from Pro Tools Expert- http://www.pro-tools-expert.com/home...ag/first-steps Anyway, on there it said 44.1 is fine for a music project, although my new interface that I want, A focusrite Liquid Saffire Pro 56 supports up to 192. Obviously I won't be using 192k, but like my title says, is 44.1k enough quality to do a standard session? Just vocals, guitars, drum, then a few VI's. I am thinking about getting Sweetwater's Ultimate Creation Station computer http://www.sweetwater.com/store/detail/CS450v3 So, judging by this computer's specs, even though I'm sure it can handle more than 44.1, is 44.1 still okay to use even though the computer can handle more? I just don't want to overuse something like 96k if I honestly don't need it. I mean I know the quality of a song gets affected by the mics you use, quality of VI's, and mixing, etc, but for all intents and purposes, say I have good equipment for all that stuff. With that in mind, would there really be a noticeable difference between a song at 44.1k, vs the same song recorded at 96k, to the average music listener, given that they are both mixed down to a standard 44.1k 16 bit for say iTunes or something? |
I would ask Sweetwater that question, it's there system. But the answers depend on what interface you are running, how many tracks, what version of Pro Tools and especially what plugins are being used. So your question is very much "how long is a piece of string". but in general yes this system should be powerful enough for most folks doing what you are doing, but you might want a dedicated Vi sample SSD or HDD depending on what you are doing.
And on any high-performance system I'd be using SSD for everything, boot/system, audio/session (always a dedicated drive) and samples. Starting with samples on the boot drive for most uses, dedicated drive for heavy use/or just some heavier VIs (e.g. NI products). As much as I like Sweetwater and their support etc. I think these systems are over priced and dislike that they do not spec the exact components they use e.g. What exact SSD drive? yes I know they are likely worried about folks just cloning their build, but too bad. If you want a powerful rock solid Pro Tools Windows box there are great threads on DUC about building your own system. e.g http://duc.avid.com/showthread.php?t=238426 Full of wonderful advice. Last edited by Darryl Ramm; 01-12-2014 at 11:22 AM. |
Re: Is 44.1 Khz 24-bit Good For a Standard Music Session With This PC?
As for 44k, the vast majority of major label music is done at that rate, so nothing wrong with that.
While I agree that 44.1K is okay(especially when starting in recording), I work at 48K these days(for 99% of my stuff). It gives a slight improvement in bandwidth, without placing any serious strain on the system(as compared to 44.1K). The choice of 24 bit is probably MORE important than 48K vs 44.1K. Plenty of hits were done on ADAT's, so work on the music more, and worry about the sample rate less
I'd add : work on the music more, worry on the gear no more...
Can you please send yourself over fiber to go spam some other forum? Darryl Ramm |
There are many different opinions about this..
I prefer working at 44.1 rather than convert down to it in the end. 48 if it's going for video and stays 48. High end quality converters will give much better results at 44.1 than low end budget converters at 192 will. For sample rate conversion, quality of conversion may vary widely between DAWs and other dedicated software. PT is not the best at it. I've read a document about iTunes preferred formats, and it said that the higher the sample rate, the better the sound will be after conversion to iTunes. If your recordings don't sound good at 44.1/24, don't expect them to sound better at higher sample rates. |
I had to go read Dave's post, I thought for a minute maybe he had recommended getting a Mac
only if you got a fat wallet. Re sample rate conversion; its gotten plenty good since the early days so I don't give it a second thought. If your final product is to be audio CD's, then you will end up at 44.1K and 16 bit, so make sure you use dither as the absolute last process(for going from 24 bit to 16 bit, having nothing to do with sample rate). If your final goal is DVD, then 48K makes even more sense
Apple working on making 24-bit music files standard | M-ManLA | General Discussion | 3 | 02-23-2011 10:51 PM |
Standard levels for VO and Music Beds DVD | dkstudios | Post - Surround - Video | 9 | 12-28-2006 12:05 PM |
What's standard behavior of "Session Auto Backup"? | Armando | Pro Tools TDM Systems (Mac) | 6 | 11-12-2006 08:52 PM |
Good drum sounds with standard plugins | Jdawgfoot | Pro Tools M-Powered (Mac) | 0 | 02-26-2006 11:16 PM |
Standard Pay for Session Engineer? | kickit | Pro Tools TDM Systems (Mac) | 28 | 07-19-2004 10:27 PM |
