Old 02-26-2006, 11:02 PM
dwayne00 dwayne00 is offline
Default having disk allocation problems
i keep getting the error disk allocation and how do i fix that when i try to get the volumes for each i get another error how can i fix the disk allocation error.
Old 02-27-2006, 10:07 AM
bluesguy bluesguy is offline
Default Re: having disk allocation problems
If you are cutting out certain regions or there are a lot of regions in a track that there is no sound happening and you have a direct in effect or indirect, like Dverb especially, then your system is working overtime on those dead regions to creat the effect. Though there is no way it can. An easy solution would be to put in a dither plugin, leave it at 24bit and disable "noise shaping". Just put that in before the Dverb or whatever plugin you think would be causing the disc alocation error. Usually it is a Dverb on a vocal track. It will NOT affect your sound quality. So dont worry about that. This should take care of that error!
bluesguy
disk allocation problems alnoose Post - Surround - Video 4 10-01-2005 11:16 PM
Disk Allocation problems when using template mrufino1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-13-2005 12:10 AM
Disk Allocation Problems Help! Infynity 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-27-2004 12:48 PM
disk allocation problems troswalt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-05-2003 08:55 AM
6.1, MIDI problems and disk allocation N.E.R.D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-01-2003 05:38 AM
