Speck Electronics EQ16-32 stereo 16ch equalizer
SOLD!
-- Limited time price DROP: $1600,-USD to 1390 -- Up for sale nice compact 3U rack analogue parametric equalizer SPECK EQ16-32. These devices in maxed configuration (16 stereo ! channels) were manufactured in quite limited quantity, so, rare to find these days. Perfect for synths/drum machines as well as to process any source, electrical or acoustical, voices. - signal path built with 5532 OPAs - accept up to +28dBu: «The channels of the Model EQ16 are line level, meaning that they may be connected to any other device that operates at line level. The EQ16 is also considered a unity gain device, which means that it has no gain. The EQ16 will operate with line input levels from -30 dBu to a maximum of +28 dBu» - complete parametric 3 band equalizer: «Each band is continuously sweepable from its lowest to its highest frequency; 50Hz to 500Hz for the low band, 500Hz to 5kHz for the mid band, and 5kHz to 15kHz for the high band. Once the desired frequency has been selected for any particular band (the center frequency), that frequency may be continuously accentuated or attenuated (boost or cut) from 0 to +15dB or -15dB» - outboard PSU, cable length 1.75m, set for 230VAC, can be switched for 120VAC Device boasts for nice shape, studio use only, no smoking. Paper manual. -- Manufacturer: http://www.speck.com/ Product: http://www.speck.com/oldproducts/eq16_2.html Manual: http://www.speck.com/pdf/misc/EQ16_Manual.pdf Internet pic from some studio with Speck(s): https://www.musical-instruments-for-...ereo-eq16.html -- Here is limited amount of pics possible, more big sized pics on your request. FREE shipping across EU/UK, call for other locations. Sending from Ukraine, with international tracking within all distance, or personal pickup in Kyiv. Payoneer payment; direct wire, PayPal is possible, with some specific, call. Crypto payments USDT are welcomed also. — Also for sale: * Eventide H3000S upgraded to D/SE, modded/improved, non humming * Technics SX-WSA1R physical modeling synt, rack version * Tripplite mains distributor for USA plug, 120V, 10 sockets * Celestion G12-T100 guitar loudspeaker 100W 16 Ohm, never used -- Electronical and studio stuff/parts: * Mogami W2944 pro audio cable, 2.5mm, 8 colors, ~236m * Canare L-4ES6 pro mic cable, Japan, 4 wires instead 2 to supress all noises, uniq offer - 5 colors * Neutrik panel mount XLRs, 3 GOLD pins, male/female * Grayhill 2, 3, 4 decks, single shaft rotary switches, up to 2x6, 1x12 poles * Grayhill 2 & 3 decks, dual shaft rotary switches, up to 12 poles * ALPS rotary switches * Luxury JBT toggle switches (USA made), never used * Carling Technologies mains toggle switches 10A/277VAC * NOBLE pots B100K * General Electric electrolytical vintage caps, never used, circa 50-60` * high voltage mica caps, 1000-5000V, Airvox, Sangamo, Sprague * Triplett ultra rare 4.5 inch VU meter * different Marion meters, 2 and 3 inch * * * Last edited by allSound; 07-17-2023 at 09:40 AM. |
Re: Speck Electronics EQ16-32 stereo 16ch equalizer
Hi, welcome to the community.
Your post was not automatically approved, because it has links and attachments. Post a little more and you won't have this problem. Slava Ukraini!
Heroyam Slava!
Thanks alot for welcoming and approving Janne, got it! |
^ top ^
^ Up ^
Hi, has it sold ?
Please let me know, thanks Regards, David |
FS: A-Designs HM2EQ Hammer stereo/dual-mono tube equalizer | mannyace | Buy & Sell | 2 | 02-03-2015 06:47 PM |
Wtb d control 16ch frame | axel | Buy & Sell | 0 | 12-19-2012 08:23 PM |
VO Pre: MBox 3 & GAP73 & Speck 5.0 | tokyofan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-09-2010 07:17 AM |
Recomendation for small 16CH analog/digital/ Mixer | Valeri | Pro Tools TDM Systems (Mac) | 3 | 12-05-2005 10:34 AM |
Speck MP 5.0 | M Lawrence | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-17-2003 02:16 PM |
