Several Issues in 1: Registration, Installation, Xpand2
Hi all,
I am looking for some help with a few questions here. I'll break it down, but first here's my specs: -Macbook Pro running OS10.7.5 (2.4Ghz core duo, 8 gb RAM) -Protools LE 8.0.3 (and upgraded to 8.0.3cs) -DIGI003 Rack 1. It started with Xpand2 losing all its presents and displaying simply "None." This is a known issue and I found several threads addressing this. I followed the instructions and located the Xpand2.big file, however once I navigated to the file it was greyed out and so I could not select it. I did not see this mentioned in any of the relevant threads. 2. I upgraded to LE 8.0.3cs, hoping the upgrade might do the trick. It did not. Same problem. So I then decided to uninstall altogether and reinstall from CD (8.0.3). Well the CD spinned forever and finally told me "Installation Failed. The Installer could not install the software." I tried several times with the same result. 3. I next decided to register on Avid so maybe they could send me a link to Protools 8.0.3 (or 8.0.3cs). I forgot I actually registered years ago and it even shows my old Mbox software (under "Lost LE Auth Code"). But for the life of me I cannot figure out how to register either my DIGI003 Rack or my Protools LE 8.0.3 software. The Registration/Activation pages on AVID.com don't accept my 003 Serial Number nor my Protools CD Authorization code...the code formats don't even look the same (which I assume is due to the Digidesign/Avid change). The Auth code worked a few years ago when I originally installed 8.0.3, so I don;t know why I can't use it to register. I see they have these Avid Support Codes, but if I can't even register my hardware and software...will they actually Support it? I am very sad right now. Any ideas would be welcome. Thanks. |
Re: Several Issues in 1: Registration, Installation, Xpand2
UPDATE: I have registered (found the card). Now I guess I have to call them? Can't find the software available for download anywhere.
Software should be available for download in your Avid account. Chris
Hi thanks for responding. I don't see the protools software available for download anywhere in the three links under "my products" on the avid "my account" page.
There are several other registered items under "view my profile details" (melodyne, torq, etc) but not protools. There is also a "Lost protools LE authorization codes" section on the avid site, but that only lists my previous 2 versions I protools, not v8. I have submitted a Registration Case so hopefully Monday someone will get back to me. |
FYI, Registration Case took care of me. Hooked up 8.0.3 on Avid site so I could download. And I haven't had the Xpand2 issue since. I think maybe I was just using too many instances of Xpand2. I had like 12 going in that session. I have reduced to 4 by making use of the 4 synths per instance, and placing that instance on a stereo audio track that the MIDI tracks output to.
Xpand2 Issues | GrantJensen | Windows | 1 | 08-10-2013 10:13 PM |
XPand2 issues | goochman70 | macOS | 13 | 03-07-2013 08:38 PM |
Re-installation Stalls at Xpand2! | CeeBeeII | Pro Tools M-Powered (Win) | 7 | 07-04-2012 01:00 PM |
Xpand2 Playback issues | gnate | Pro Tools M-Powered (Mac) | 1 | 04-19-2009 11:44 AM |
Registration issues and PT 7.0 | sebamars | Pro Tools TDM Systems (Mac) | 1 | 11-10-2005 11:17 AM |
