Edit Selection change w/ Undo/Redo Select Playlist
Hi All,
I've just started using PTLE7.1. Before that, I was using 6.4. The problem I am having is this: I usually have separate playlists for each take. For auditioning takes when creating a combination track, I browse back and forth between the takes with Undo/Redo on the keyboard once I have loaded the desired playlists into undo history by activating each in a given order. This saves me mouse clicks and time! With 6.4, edit selection remained the same while I was browsing between playlists with undo/redo. With PTLE7.1, edit selection started following the undo history. Say I decided to audition few more or less bars or beats and change the selection accordingly on the active playlist. When I undo to return to the previous playlist, my new edit selection goes to trash! This is annoying for the way I like to work. I couldn't find a preference or option that sets this behaviour. Anyone have a similar issue? Cheers. Krofa. |
I want clip fx + undo redo | tilman | Post - Surround - Video | 12 | 07-10-2014 04:57 AM |
Vertical Jumping With Edit Selection In Playlist View | soundlabyrinth | macOS | 11 | 09-24-2012 06:37 PM |
Undo Playlist Edit Bug. | Dizzi45Z | Pro Tools TDM Systems (Mac) | 1 | 06-30-2010 09:49 PM |
CAN NOT UNDO/REDO!!! ALSO... | M2E | Pro Tools TDM Systems (Mac) | 12 | 09-02-2007 03:15 PM |
Time to REDO the UNDO !! | frenchman | Pro Tools TDM Systems (Mac) | 4 | 11-28-2004 10:48 AM |
