Old 04-23-2004, 12:59 AM
Johnny916 Johnny916 is offline
Default How good are the Digi 002 preamps?? Should I get
I was wondering how good my digi002 preamps are, I have the control surface. Should I invest in a high quality preamp? If so, which one?
Never underestimate the predictability of stupidity!
Old 04-23-2004, 05:32 AM
Saberon Saberon is offline
Default Re: How good are the Digi 002 preamps?? Should I get
I actually don't mind the preamps on the digi002, they are quite clear and they are pretty receptive and accurate in the sample by sample capture through their A/Ds. Their preamp is nearly noiseless, and besides that a little noise can give an analogue quality to your mix which can be benificial. What you have to think about is how many pres you require. You might wanna consider a focusrite platinum octopre with lightpipe Adat option card giving you 12 preamps to work with. Its totally about what you wanna use it for.
Cheers
Cammie
Old 04-23-2004, 05:35 AM
Chris Cavell Chris Cavell is offline
The 002 pre's are very clear, very hot, and not very versatile (no pad to accompany their extreme "hotness"). A second pre to compliment the setup is a good idea. The 002 pre's are actually used quite often on my 002 rig, but having others is a must (I wouldn't dream of tracking drums with them).
Cavell Studios
Old 04-23-2004, 07:09 AM
jjhuntfox jjhuntfox is offline
The Octopre or the Digimax are great additions because of the light pipe. It gives you 8 more pre's and uses the light pipe input. I like my Octopre Mic Pres'.
If you want something a little more high end there is a cool mic pre kit out that is really high quality. Two channels for under $700. Here is a link if you want to check it out. You'll have to solder and put it together but it'll stand up to any high end mic pre out there. There is a tube and a solid state kit.
Hamptone Mic Pre
John
M-Audio 410 preamps better/same/worse than Digi 001 preamps? SixChurchStreet Pro Tools M-Powered (Win) 0 02-20-2008 12:08 PM
Mic Preamps on Control24, Good? Marius Eikeskog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-23-2005 07:36 AM
Focusrite Preamps and Digi 002 Preamps ?? rj333 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-01-2004 09:19 AM
ST Audio Preamps...any good nightshade crisis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-11-2002 03:12 PM
Good Mic Preamps under $500 psax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 31 09-24-2001 04:08 PM
