Problem record in sync more than 4 tracks.
I use with ProTools24-MIX with 5.13 soft. Normaly I havent problem record 24 tracks but I have problem record to Protools online synced with SMPTE.I need to record in sync from DA-88 8 tracks to Protools.I use Rosendahl Nanosync as house masterclock sync generator,DA-88 with sync card, Tascam convertor TDIF-ADAT, ADAT Bridge and Emagic Unitor 8 mk2+ as SMPTE reader. I sync DA-88 and ADAT bridge with house master clock Nanosync-this work without problem.When I put Protools online to record from DA-88 with SMPTE and try to record 4 tracks Protools waiting for sync SMPTE LTC code (25 fr) and after 1-2 sec synced to SMPTE and starts record online synced with SMPTE positional and superclock house speed synced from Nanosync.It works...BUT when I arm 8 tracks, put ProTools online and try record from DA-88 ProTools waiting for sync try to find sync but cant start record.When I put Protools online and play Protools synced with DA-88 it works correctly,recording from DA-88 online 4 track also works correctly,but why Protools cant record online more than 4 tracks?I try change DAE buffer to 512 change Memory for Protools to 200 MB and DAE for 120MB,but not solve problem. Why Protools record SMPTE online 4 tracks but cant record 8 or more track online SMPTE synced?I use G4 mirror drive comp and OS9.22. Thanks for response. |
Re: Problem record in sync more than 4 tracks.
Don't connect any WC signal from Nanosync to DA-88/IF-TAD.
The only WC cable goes in between IF-TAD & DA-88. (Light Pipe signal in between ADAT Bridge & IF-TAD includes clock already). Set Clock on DA-88 to Word. Send SMPTE from DA-88 to your Unitor 8 mk.2 --> PT. Set PT to sync from Unitor, go online & activate Record. Push play on DA-88. This should work ewery time: DA-88 to PT. ============= The outher way around is: Send SMPTE/MTC from PT to Unitor --> DA-88. Set DA-88 to Chase. Ev. set correct Offset on it. Play in PT & push Play & Record on DA-88 after the deck is in sync. Good Luck
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
Weird Sync Problem in Record | jim latham | Pro Tools TDM Systems (Mac) | 0 | 08-11-2005 10:41 AM |
record armed tracks mute problem | lightning ad | Post - Surround - Video | 2 | 05-26-2005 03:05 PM |
New tracks record out of sync (early) HELP!!! | WildHoney | Pro Tools TDM Systems (Mac) | 2 | 05-25-2005 10:52 PM |
No MTC sync with 8 tracks in record | Kurt Riemann | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-08-2004 01:34 PM |
Limited record tracks in ext sync | Mikenutmeg | Pro Tools TDM Systems (Mac) | 3 | 06-25-2001 09:21 AM |
