Old 06-30-2022, 01:45 PM
Ben Jenssen's Avatar
Default Plugin menu favorites
I never used the plugin menu favorites feature much, but I thought I'd clean it up and start using it more. Good when using Artist Mix.
I have plugins sorted by both category and manufacturer, and I like it that way. Now, I can add a favorite by holding command and clicking it. It shows up inn the plugin menu above the categories. If I command-click it again it goes away.
Here's what I can't seem to fix, it's probably something simple; A couple of plugins sits in the menu, one level up; under 'search…' and above 'Plugin'.
I've tried every modifier key, searched, and tried a tip I found about holding opt-cmnd and clicking 'No insert', which is supposed to clear all favorites. It clears the favorites I mentioned first, but not the ones under 'Search…'.
Any thoughts?
Old 06-30-2022, 04:11 PM
Default Re: Plugin menu favorites
I find that the two favorites I can't get rid of (under 'search' and above 'plugins') shows up on the artist mix controller. But if I create a new favorite (cmnd-click) it shows up above categories and manufacturers - but are not available on the artist mix.
I have a sense that this might be eucon-related. I've tried setting favorites with the artist mix powered off, it makes no difference.
Old 06-30-2022, 06:04 PM
Nope. Just my own stupid fault.
The two 'favorites' is simply the prefs setting 'default EQ and dynamics'. Set them to none and they're gone. Also I am now able to see my newly created favorites on the controller.
Move on. Nothing to see here.
SOLVED - Plugin Favorites Disappearing? - A Manual Update & Warning Dialog Box!!?? tmuzik Pro Tools 0 07-09-2021 12:13 PM
Plugin Favorites Bug Jperkins Pro Tools 12 2 06-27-2017 06:02 AM
pro tools plugin menu, and options menu blank lucidlife Pro Tools 10 4 12-07-2014 12:16 AM
Plugin Alliance Favorites...? WKG AAX Plug-ins 4 12-31-2013 02:29 PM
plugin menu clausiii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-28-2003 11:41 AM
