#21
Re: Video engine in 22.5 and 22.6
Also AVID own video hardware is rebranded BM so I think the whole product line might be closer integrated and tested since their driver compatibility charts is essentially the same drivers that BM make and publish. Even though AVID officially says neither AJA nor BM are specifically tested or supported. But regardless I have a Kona LHI (man, AJA is crazy expensive if you want a genlockable card) coming in from ebay to do a quick test. My guess is that it's a driver issue but since BM v11.4.1 is the last one that works with Mojave (since 11.5 and 11.6 are broken) I won't be able to upgrade to the one that AVID recommends for 22.5/22.6 unless I buy a whole new computer or go the OpenCore route. I'm definitely not investing 1500-2k$ for an AJA card just to have something that's the same as before. I'd rather go back to PT21.12 until the dust has settled with Rosetta speed issues. But since other 5,1 Mac users don't seem to have the problem in the end it might not even be a BM issue in the first place. Will see... F.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
#22
Hi Frank.
PT 2022.4/5/6 are "macOS Mojave (10.14.6) untested, but expected compatibility" 2021.12 is tested and qualified with macOS Mojave 10.14.6. Could this be a crucial difference here? Best henning |
#23
Thanks Henning,
22.5 had Mojave listed (as well as all the other 22.x releases) as compatible. 22.6 is the first release that had Mojave dropped from the list. F.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron Last edited by Frank Kruse; 07-04-2022 at 02:49 AM. |
#24
Hi Frank,
for me it seem a bit the other way around. I was on OS10.14.6 and PT Ulti 21.12 with a AJA T-tab and had 10+ Video Stops/day. (Always a Video Error after not touching PT for a minute). Very annoying. I recently went up to OS 11.6.7 and PT Ulti 2022.6 and video seems to run much smoother.
Béla Brandes | www.bbsounddesign.de |
#25
Hm, so much for the ever so "flawless" AJA
#26
Got some more feedback from other 5,1 users in my area who confirmed similar issues.
One on AJA Kona LHI who said 22.4 was a desaster for him. 22.5 slightly better but not great. Another on BM with the same issues. I went back to 22.4 today and so far it's been fine. F.
#27
Update:
I have now replaced the video engine in 22.6 with the one from 22.4 and everything seems stable and back to normal. Even the TC-overlay still works with the older engine Will see how it behaves over the rest of the week. Frank.
#28
Ive noticed a few extra video engine errors creeping in on 22.6. I'm decklink and PC though.
I usually restart, and the PC is really slow to restart after these errors.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest |
#29
I've been having loads of video engine issues with 22.6 also - the video track seems to switch from blocks to frames by itself followed by error messages saying 'unable to create thumbnails on video track'. Anyone else getting this? I've found that hiding the video track seems to help...
#30
Perhaps I'm blind, but did 22.7 remove the "disable external video hardware" option under the setup menu that appeared in 22.6 (or perhaps early)?
I've been having loads of issues with Pro Tools in the recent updates. It is has all been smooth sailing since yanking the BM card out of the system entirely... which really isn't ideal.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
Video Engine Crash with No Video in Session | JKHansen | Pro Tools | 0 | 06-28-2022 11:33 AM |
'The Video Engine reported and error' message when trying to play any video | zerothrills | Pro Tools 12 | 10 | 02-28-2022 04:04 AM |
Video Engine "Network clock is not locked" error when screen sharing video over skype | piuretig | Post - Surround - Video | 0 | 01-12-2022 01:37 PM |
Video Engine Fail "Waiting for the video engine to launch" | oscar_wonderboy | macOS | 5 | 08-14-2018 01:22 AM |
Video Engine not working.. crashing when i load in a video to PT11 | sarahsherlock | Pro Tools 11 | 5 | 08-16-2014 12:35 AM |
