Old 04-29-2022, 03:31 PM
EddieJones's Avatar
Default EUCON 2022.4 Released
Avid is pleased to announce the release of EUCON 2022.4 Download it from your Avid Account or the Avid Download Center.
Blog post
Whats New Guide
Old 04-30-2022, 03:35 AM
Default Re: EUCON 2022.4 Released
Will EC22.4 work with PT21.12 and S1?
AVID info says no, co-workers say yes.
What your experience? A case of "may work, but not supported"?
I can't yet jump on PT22.4 but really would like the coloured softkeys for visual feedback on preview and clear solo status.
Thanks!
Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 05-02-2022, 06:40 AM
So I tried it. EC22.4 with PT21.12. Works fine. The softkey colors on S1 seem to be quite buggy. Colour assignment only seem to update after pressing the keys. Also I have my default layout assigned to a softkey are it's super-bright red even though I have dark blue assigned to the key. It goes to the correct colour when I switch the key to a different layout but when hitting shift on the S1 it goes back to bright red. So overall I can't find a way to change to super bright red it uses for my layout. Also no idea where it gets the red color info from. After a bit more messing around the key with my layout is now very bright neon PINK even though it's got a very dark yellow assigned. Strange. It functions fine but the colours for layouts seem completely random. hm...
Same on PT22.4
Frank.
Old 05-02-2022, 06:57 AM
OK I think I know what the bug is.
I've got another layout on the same key with shift which is pink. Pressing shift recalls the color of that layer but releasing shift doesn't make the key fall back to the colour assigned to the non-shifted function.
So you need to assign the colour you want on the 7-key to the shift-7 key to work around it. Not great but at least that way you can set the extremely bright default colour to a lower level.
Old 05-02-2022, 12:34 PM
EddieJones's Avatar
Softkey colors only come on when the control is on.
Old 05-03-2022, 01:24 AM
Thanks Eddie, not sure I understand.
I have a layout recall assigned to one of the S1 softkeys. I also have set dark blue as its colour in the EC softkey settings and yet it is bright pink (which is essentially the colour of the same key but on the shift-layer). Not sure that's intended (?)
Cheers!
Frank.
Old 05-05-2022, 06:44 PM
kings79's Avatar
kings79 kings79 is offline
Hey Eddie, we can't seem to get 2021 MC User Sets working on this new version.
Re-Recording Mixer/Sound Designer
Sydney Australia
OS Monterey
ProTools Ultimate 2022.4
Presonus Quantum 4848
Mac Studio M1 10 Core, 64gig RAM
Sonnet Echo dual NVMe TB Dock
Blackmagic Decklink 3G
Old 05-06-2022, 08:43 AM
EddieJones's Avatar
Cheers!
Frank.
Are you sure you are not locked in shift?
EddieJones's Avatar
Did you try to import the old set?
Old 05-06-2022, 08:46 AM
I am. My shift is set to toggle while pressed only. (Latching shift OFF in settings)
Should be easy to replicate. It's only the set colour the first time I press it. Once I pressed shift it will use the colour of the shift layer and never come back to the non-shift colour. Until I restart or force a color reload via the EC app.
Eucon 2022.4 Cheesehead Avid S1, S3, Dock and Control App 9 04-28-2022 08:54 AM
Ozone 9 Advanced Version 9.12 released April 8, 2022 gives AAX Plug-ins 0 04-10-2022 02:27 PM
EUCON 20.6.1 released EddieJones Avid S4/S6 0 05-21-2020 10:30 AM
EUCON 20.1.0 Released EddieJones Avid S1, S3, Dock and Control App 44 05-08-2020 11:59 PM
EUCON 20.1.0 Released EddieJones Avid S4/S6 11 03-09-2020 11:35 AM
